Just had left side diff plate replaced part #12458145 this came with seal & O ring already installed. I assume /hope that this plate had updated seal & O ring in it. My 2nd ? is receipt showed 2-89021677 , & 1-1052358 lubricants are these alright to use. I thought the correct Part# were 12378261 & 1052358 synthetic lube & limited slip lube.
Did they just install dino oil & is this Alright since my 00 vette came with synthetic ?
I am lurking because I recently had the same repair done and the lube nbrs are the same as yours. I got the "new" seals and I hope the fix is permanent.
About 6-8 months ago GM changed the design of the bottle and because of this also changed the part # for the synthetic lube as well. 89021677 is the correct stuff
C-5 TECH Once again you came thru for many thanks.
