[Z06] Can Battery Effect Alignment On ZO6?
Old Sep 19, 2004 | 03:37 AM
LIGHTNING's Avatar
LIGHTNING
Default Can Battery Effect Alignment On ZO6?
From what I understand, the stock ZO6 battery is a special light weight Delco. If you replace it with say an Optima, which weighs more, would this have any effect on wheel alignment due to weight difference?
Old Sep 19, 2004 | 05:28 AM
Shylor's Avatar
Shylor
Hardly anything worth worrying about.
Old Sep 19, 2004 | 06:19 AM
02 batmobile's Avatar
02 batmobile
a lot less than having your wife sitting next to ya!!!
Old Sep 19, 2004 | 04:29 PM
Shylor's Avatar
Shylor
Or having you sit in the car. Considering the alignment is done without anyone in the car.
Old Sep 19, 2004 | 06:14 PM
TheDVS1's Avatar
TheDVS1
Does Optima make a battery close in dimensions to the dimunitive Delco that came with the Z?
Old Sep 19, 2004 | 07:51 PM
johnC5's Avatar
johnC5
Default About 1 lb difference...
About 1lb difference:
http://forums.corvetteforum.com/show...=johnC5+optima
See also: http://forums.corvetteforum.com/show...=johnC5+optima
Considering that the newer C5's came with even heavier batteries (they switched back to non-AGM in 2004, perhaps earlier); nothing to worry about.
When my AGM died, I went with the warranty replacement, the non-AGM 75-7YR Professional (rated about 2.5 lbs heavier). No change in tire wear or handling: not a significant weight change relative to total weight.
Old Sep 19, 2004 | 08:35 PM
ZO6Les's Avatar
ZO6Les
If your shop does alignments without you in the car get a new shop!
As far as the battery goes it will not have any effect on alignment.
Les
Old Sep 19, 2004 | 10:09 PM
boss95z's Avatar
boss95z
my shop put weights in the drivers seat
To Can Battery Effect Alignment On ZO6?
