A/C drain hose
Old Oct 7, 2004 | 08:40 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default A/C drain hose
I getting ready to install the hose on the pipe coming out of the firewall (which is no easy task) and was wondering what's the slickest stuff I can apply to the inside of the hose to help it slip on?
Old Oct 7, 2004 | 10:10 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
If it's hard to get in I'd use dielectric grease. It won't harm the rubber. Hope that helps.
Old Oct 8, 2004 | 12:22 PM
erkjr's Avatar
erkjr
Cruising
Default A/C drain hose install
I recently replaced this little jewel....
Stockman was right about the di-grease, but I used some silicone
seal/glue, hoping that it would help keep the hose in place.
It's been about 6 weeks, and it's still in place.
Now for the fun!
My large hand couldn't get the hose in place, and my wife couldn't do it either.
Here's what finally worked: I'm under the car with the light,
holding the hose in place with a length of 1/8" rod and my wife's small hand reaches in from the top and pushes the hose onto the pipe.
Whew!! But cold air and dry carpet is a GOOD Thing!!
Good luck.
To A/C drain hose
