Can you powerbrake in "Competitive Mode?"
I tried to bump up the RPM's in my car for a good launch yesterday and was surprised to see that my car wouldn't let me do it- it would just retard itself. With the t/c and AH turned off, it was no prob, but I'd really like to keep the AH on to help me with the 500rwhp.
I swear I've powerbraked it before in Competitive Mode......No?
Any thoughts?
-Jason-
Any thoughts?
-Jason-
No reason why you cant.
It only turns off Traction Control so the wheels can slip and it wont reduce your engine power. Other than that you can drive the same as you do.
I don't think you could do that in a pre-2001 or 2002 Vette. I know I can't do it in my 2000 - bogs down when I try to do a burnout. I'd have to turn everything off, which is not what I want to do - Active handling is everything its supposed to be.
I'm sure someone else will chime in, but I'm pretty sure they fixed it in later C5 years.
What kind of tires are you using to plant that kind of power to the pavement? I can't imagine why power braking is necessary with 500 RWHP.
295/35/18 BFG Drag Radials 10.5 inch rims. I don't need to power brake it a lot- just enough to get under a little boost for a solid launch. I need all the help I can get with the 2.73 in my car. From a dead stop, with the BFG's on and no power braking, it will barely chirp the tires....and I mean barely. It's a lot worse from a 35mph role- it's almost undriveable without the AH on.
As for the Active Handling. First Generation was 97-00. Second Generation was 01+.
I've been able to spin my rear wheels off a launch in competition mode in first, but having a manual tranny, street tires and a Z, I don't need to power brake. All I would do would be waste a lot of miles on my street tires.
From a dead start with no powre braking it will smoke the tires and go sideways all the way through 1st and 2nd.It's a 98 with active handling. I do those burn outs in comp. driving mode. I don't race, I just do that once and a while for fun.
The A/H is doing what it is supposed to do while trying to power brake; helping you to maintain control. With it turned off, or into competitive driving mode you can power brake the rubber right off the tires. I suppose you could power brake with A/H off and then once out of the hole push the button back on if you feel like you can drive with one hand for a second. Man, that is some good pony's on the ground
Man, that is some good pony's on the ground :thumbs
power brake
Any thoughts?
-Jason-
Any thoughts?
-Jason-
Originally Posted by shurite44
I have a 03 coupe, I can power brake in competative driving mode. But with Active Handling on it will bog the engine. Active handling off, and comp driving mode power braking is possible.
Originally Posted by WWK888
Isnt Comp Mode Active Handling on and Traction Control off? I am confused by your last sentence.
Default setting= AH on and Traction Control on
One push=AH off, Traction Control off
Hold button for 5 seconds= Comp Mode AH on, Traction Control off
I posted a similar question sometime back. My '01 coupe would not allow me to power brake with TC/AH on, off or in comp mode. Regardless of settings, if I stood on the brake to load the converter and then let off a little to let the wheels spin, it bogged down. I believe that it is the torque management working to prevent "abusive manuevers". Unlike TC and AH there is no control over Torque Management from what I have read.
The good news....if you don't press the brakes too hard and ease into the throttle to get the tires spinning, there is a point around 2200 rpm it seems that the car stops fighting. Then you'd better hang on and be ready to peddle and drive cuz the revs are going skyward, the tires are becoming molten masses of spent rubber, the smoke is threatening to obscure all visual aids within a quarter mile and the the rear end wants to lead. Wooohooo, I get excited just thinking about it.
P.S. I've learned to respect the AH so I use comp mode, especially at the track.
1 Post
St. Jude Donor '05
CI VI Veteran
Got a question with no flame in mind. I love the AH feature GM incorporates in the vette. It gives an added sense of security to my inability to control the car when I mess up.
However, what's the big deal with AH at the track? Millions of cars drive down the 1/4 track and not one has AH except the vette. They never seem to have problems... what's the big deal?
Like I said, no flame, I just don't see the need for AH on a straight line 1/8 or 1/4 mile track. I could see if we were running on the salt flats in Michigan trying to obtain top speed or something.
Just wondering?
Mark
Just wondering?
Mark
Just wondering?
Mark
Just wondering?
Mark
