suspension woes
Old Nov 10, 2004 | 05:46 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
Default suspension woes
i got BMR front and rear sways on 2 months ago, but when i hit bumps i feel something hit. Could it be hitting this black thing? Chevy and Pepboys said that everything was tightened down. No one can figure it out...BMR offered to look at it but its a 4 hour drive there.
Old Nov 10, 2004 | 06:34 PM
Patches's Avatar
Patches
You should be able to see telltale signs of contact where the paint/pc will be gone at the point where they touch if they do. Sway bars can sometimes hit other components which is why some of the aftermarket manufacturers supply restraining collars to restrict their movement.
Usually, if you start getting noises after a sway bar install, either they weren't sufficiently tightened, they have loosened up or their movement needs to be restricted.
Old Nov 10, 2004 | 08:12 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
who sells restrainers? I am having mike norris look at it in a few weeks.
Old Nov 10, 2004 | 10:29 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
If you're having Mike look at your car you might get them to just check to make sure the sway bars are properly torqued first. You may not need to restrict them.
Old Nov 11, 2004 | 06:51 AM
Patches's Avatar
Patches
Mike will fix you up. I'm sure he'll check the installation and ensure the fasteners are torqued properly.
Old Nov 11, 2004 | 06:56 AM
LuS1fer's Avatar
LuS1fer
No help but I had a knock on my rear BMR sway bar on my Z28. I was fuming then realised I'd fitted it upside down. You gorra larf.
Old Nov 11, 2004 | 07:39 AM
YO-EL's Avatar
YO-EL
Could be the leaf springs lost their arch...
I replaced my rear one & no more noise over bumps or dips in the road..
Just a thought........
To suspension woes
