[Z06] Windshield fluid leaks during hard accelleration.
Old 07-25-2001, 12:19 PM
Grendel
Grendel's Avatar
I know I have read something in the forum about this issue, but I can't find it. Is there a fix to to this, or do I just live with it. I am a little **** about keeping my car clean and spot free. This is almost as big of an issue with me as people watering their lawn, causing large pools of water to accumulate in the road.
Old 07-25-2001, 12:31 PM
EILIG
EILIG's Avatar
DITTO!!!
Mine does the same thing. Except that I've noticed the liquid that emits during hard acceleration is NOT washer fluid, but rather water (most likely from the most previous washing) that has settled and remained in that screened-in little air-intake area at the base of the windshield on the driver's side.
You can instantly tell how hard a Z06 has/has not been driven by the quantity of hard-water spots at the base of the windshield on the driver's side!
-Jay
Old 07-25-2001, 12:36 PM
DLSCWBYVT
DLSCWBYVT's Avatar
I believe everyone experiences this, unless you do not hard excelerate I am not aware of a fix for the problem.
Would like to know if there is one though.
Old 07-25-2001, 12:53 PM
Gordy M
Gordy M's Avatar
I have the same problem, especially when I am autocrossing the car. The only solution I have found is keeping the windshield solvent level low. Some times after a run, I find the cap is slightly tilted, I even tried taping the lid down but it comes out the breather hole in the cap.
Old 07-25-2001, 01:30 PM
bigsapper
Support Corvetteforum!
bigsapper's Avatar
There's a fix using a check valve. It's described in this thread. http://www.corvetteforum.cc/ubb/Foru...ML/019361.html
ChrisG
Old 07-25-2001, 02:35 PM
E RACER
E RACER's Avatar
Going up a steep hill and punching it really lets the bug juice flow. Eventually it will run out of washer fluid. Sure beats oil consumption problems.
Old 07-25-2001, 02:41 PM
tjfees
tjfees's Avatar
I have not noticed this one, but I have not filled it yet either.
I have a problem with loose items flying all over the interior when I'm trying to drive. I hit the brakes hard once and the folded sun screen went flying from its perch behind me and then the wind from the open windows opened it up right beside me! That was fun batting that thing down and trying to avoid other traffic! Now I stuff it under the seat
Old 07-25-2001, 03:47 PM
Grendel
Grendel's Avatar
Thanks for the link to check valve fix. I will look into it. Now I just need to find a fix for those sprinklers!
Old 07-25-2001, 04:03 PM
bigsapper
bigsapper's Avatar
Originally Posted by Grendel:
[B
... Now I just need to find a fix for those sprinklers! [/B][/color]
Aargh!! I hate that too! How hard is it for people to grok that no matter how much you water the concrete, it doesn't grow! [img]http]//www.corvetteforum.cc/ubb/rolleyes.gif[/img]
ChrisG
To Windshield fluid leaks during hard accelleration.
Quick Reply: [Z06] Windshield fluid leaks during hard accelleration.
