FS: Wilwood Brake Kit 4 Piston Fr/Rr Direct Factory Replacement C5/6
I have a brake kit that I bought used with 1500 miles. Wilwood says they are the direct replacement kit for a C5/6. They will not fit under my front rotors as they are aftermarket rims. I'm selling for 950 Shipped.
Calipers with pads
Rotors
Everything, lines for C5 and C6. (2 Sets)
Calipers with pads
Rotors
SLC56 Front Replacement Caliper and Rotor Kit
140-15175
4-Piston Front Kit
12.8-in Rotor Diameter
1.25-in Rotor Width
DPC56 Rear Replacement Caliper and Rotor Kit
140-15176
4-Piston Rear Kit
12.01-in Rotor Diameter
1.04-in Rotor Width
I do not want to separate.
140-15175
4-Piston Front Kit
1.25-in Rotor Width
140-15176
4-Piston Rear Kit
1.04-in Rotor Width
FWIW, I run this setup on my 01. The fitment is great. Excellent stopping power. Modern look. Only downside was that I ended up getting 5mm spacers all around cause there was less than 1mm gap on the fronts with my stock thinspokes. Wasn’t going to risk it.
jz94 (03-17-2019)
Since what you have are stock C5 wheels then they should fit yes. I would double check with Wilwood just to sure though. As these are a direct replacement brakes then i would think they would fit the rims you have.
