C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
ECS Mail order tunes, still only $149!
Old 08-10-2009, 02:59 PM
  #41
docbrew
CF Senior Member
docbrew's Avatar
I knew I was forgetting to do something this summer! Thanks for the reminder.
docbrew is offline
Old 08-10-2009, 05:42 PM
  #42
MY5THVET
CF Senior Member
MY5THVET's Avatar
PCM sent out today, can't wait to get it back
MY5THVET is offline
Old 08-10-2009, 06:26 PM
  #43
08JSBZ
CF Senior Member
08JSBZ's Avatar
how about better mileage? I have been told that they will be leaned out...obviously not too much to be dangerous.
Thanks in advance
08JSBZ is offline
Old 08-11-2009, 01:39 PM
  #44
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I'll turn it around same day.
Thanks in advance
We generally see 1-2 mpg gains, if you look at the thread regarding "dyno results of a mail order tune", it is confirmed there as well along with dyno results of our tune.
DOUG @ ECS is offline
Old 08-11-2009, 03:24 PM
  #45
Chicago1
CF Senior Member
Chicago1's Avatar
I was looking at that dyno and he said he got 8hp and 12tq but it seems more like 20 or so. Can you explain or break it down in "dyno sheet's for dummies" term?
Chicago1 is offline
Old 08-11-2009, 07:20 PM
  #46
wandrew1
Junior Member
Originally Posted by DOUG @ ECS View Post
Not a bad problem to have!
All part of the $149 tune! We can send the thermostat at the same time if you like.
Yup, no problems at all running a 160 stat no matter how cold outside.
Doug, can you give me some guidance in pulling the PCM? How much is the thermostat, and what will be the turn around time?
wandrew1 is offline
Old 08-11-2009, 08:04 PM
  #47
RDnomorecobra
CF Senior Member
RDnomorecobra's Avatar
ok, dont laugh, how do I pull the PCM. novice wrench turner here, though I just successfully installed my Halltech! hope I put it on right.
RDnomorecobra is offline
Old 08-11-2009, 08:29 PM
  #48
twcman306
Junior Member
^^^^This
Also sorry for the novice question, but what exactly is the advantage of a tune? I have a 01 auto with a Z06 exhaust and a VR intake. More power?
twcman306 is offline
Old 08-12-2009, 10:31 AM
  #49
DOUG @ ECS
DOUG @ ECS's Avatar
We will post up a tutorial shortly on pulling the PCM, it's pretty easy.
Old 08-12-2009, 10:38 AM
  #50
JW Motorsports
Supporting Vendor
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Mine was pretty stuck. It took me a few days to figure that out though.
My PCM should arrive today.
JW Motorsports is offline
Old 08-13-2009, 10:03 AM
  #51
DOUG @ ECS
DOUG @ ECS's Avatar
Arrived, and returned yesterday! Thanks for the business.
Old 08-13-2009, 10:51 AM
  #52
JW Motorsports
Supporting Vendor
Thanks Doug!
Old 08-13-2009, 09:12 PM
  #53
MY5THVET
CF Senior Member
MY5THVET's Avatar
Got my PCM back today, only sent it out Monday afternoon...wow that was a quick turnaround!
Thanks Doug
Doug
MY5THVET is offline
Old 08-18-2009, 06:41 PM
  #54
tech2262
CF Senior Member
tech2262's Avatar
Question if I would get a tune from u guys do u think u could set my fuel shutoff to 255
tech2262 is offline
Old 08-19-2009, 02:28 AM
  #55
mAydAy121
CF Senior Member
St. Jude Donor '10
^^^ I have the same question, having some crazy column lock problems and the bypass didn't solve it
mAydAy121 is offline
Old 08-19-2009, 08:14 PM
  #56
DOUG @ ECS
DOUG @ ECS's Avatar
Thanks Doug!
Thank you!!
Thanks Doug
Doug
Thank you too!!
I certainly can, just leave any special requests taped to the PCM with a mod list and contact info just in case.
I can shut off the fuel cut off that occurs at 3 mph when the column lock is stuck on, but if there is a mechanical failure in the column then the tuning will not obviously fix that.
btw, I do that automatically with all the tunes.
Old 08-21-2009, 08:19 PM
  #57
tech2262
CF Senior Member
tech2262's Avatar
thanks that is great to hear that you guys do that, now i can sleep at night. I will be at carlisle maybe i will get a tune depending on if i get headers or not
tech2262 is offline
Old 08-23-2009, 06:17 PM
  #58
JW Motorsports
Supporting Vendor
I finally got my PCM back in and tested everything out with the new headers. The car is a beast now! I was amazed at the difference (a buddy of mine was also).
Anyone on the fence I would strongly suggest getting off and sending your PCM to ECS. They do great work.
Thanks guys!!
Old 08-24-2009, 10:58 AM
  #59
DOUG @ ECS
DOUG @ ECS's Avatar
We'll see you there!
Thanks guys!!
Great to hear, thanks !!
Old 08-24-2009, 01:22 PM
  #60
Chicago1
CF Senior Member
Chicago1's Avatar
Chicago1 is offline
Quick Reply: ECS Mail order tunes, still only $149!
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
