C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
2000 corvette
Old Nov 3, 2013 | 01:36 PM
mjp802's Avatar
mjp802
3rd Gear
Default 2000 corvette
abs, tc, and check engine soon light on at the same time, been on for about 4 months tried to reset but to no avail. can anyone help?
Old Nov 5, 2013 | 07:58 AM
warlock007's Avatar
warlock007
If i remember correctly thats the ECBM, you can take it out and send for repair, i sent mine to a place in MA for like $69.
Do you get codes? what are they?
Clear DTC press and hold Options while pressing fuel 4 times let it run through while your writing down the codes.
Post them when done
Old Nov 5, 2013 | 03:18 PM
mjp802's Avatar
mjp802
3rd Gear
Default codes for 2000 corvette
10pcm- p0174h, p0141c, p0171h, p1431h, p1571hc
28tcs- no comm.
40bcm- b2723h,
58sdm -u1040hc
60ipc- u1040h
99hvac- b0367h
Old Dec 11, 2013 | 09:20 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The U codes and the B codes I would not worry about. Also lost comm. Often these are a result of a dead battery or having disconneted the battery
The P codes are for the powertrain which includes the eng and trans
p0174 is a lean code for bank 2 pass side
p0141 is an 02 code for the drivers side rear 02
p1431 is a fuel level sensor 2 code
p1571 is a traction control "request" code
A lean code canbe createdby several things. I would check the drivers FRONT 02 and also clean your MAF
The rear pass 02 code can be a faulty 02 or bad pigtail
The fuel level code is a tricky one. Could be signs of a bad fuel pump because of the lean code as welll. Does your fuel gauge work corre tly ???
Finally the TC code can bemany things but most often is a result of a bad wheel speed sensor located ar eah wheel or a dirty pigtail or frayed wire on the pigtail--- clean and inspect each pigtail
All thesecodes as a last result canbe permanently deleted with a tune and never re appear. However iwould try to fix the TC code cause if a wheel sensor is fouled you will not have either ttraction control but most importantly NO ABS BRAKES
Old Dec 11, 2013 | 10:46 PM
baxsom's Avatar
baxsom
Post them when done
only the 01+ can be repaired unless there has been some major breakthrough in the past few months.
To 2000 corvette
