C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
need help with graph on tech 2
Old 01-01-2017, 01:27 PM
04zjimc
04zjimc's Avatar
Default need help with graph on tech 2
Not sure if this is normal?
Old 01-01-2017, 11:22 PM
RedRiderZR1
RedRiderZR1's Avatar
No. Not normal. You are getting misfires across the board. Give some information on your car. Running headers and a cam? If running a cam you can see misfires logged like that. Otherwise looking like another issue.
Old 01-02-2017, 08:07 AM
04zjimc
04zjimc's Avatar
hi, car is a 04z 30,000. ​​​​​​​mods are...xs headers,catback, varram and a mail order tune from ecs. My issue is hard to explain but it felt sluggish low rpm, then out of nowhere power comes back..almost feels like brakes are being applied then released wierd. Car is well takin care of very strange issue! Oh no codes...new plugs, wires are msd 1 1/2 old. Also I noticed the misfire count would go up when I pushed my clutch pedal down than release..? Not sure if that's normal? My clutch don't make noise other than the normal sounds...
Old 01-08-2017, 05:11 PM
04zjimc
04zjimc's Avatar
my other issue I have been having is, with no codes or stored codes..feels like brakes are being applied..best way to describe it is picure driving with your emergency brake on then...you release...with having the tech 2 where would you start to look? Thanks
Old 01-13-2017, 02:20 AM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
If you do nor hear or feel any real noticeable misfires----Then all your misfires are what they call "false misfires" False misfires are most often caused by LT headers an aftermarket clutch or flywheel---The thin walls of the tubes will produce new strange noises that the knock sensors will interpret as a misfire or knock Even a false misfire will make your engine run lazy as will a false knock situation---as timing will be greatly reduced---Running you engine too long will drop your engine into a reduced power mode and as well make the ignition timing drop to almost 1/2
A lightened clutch or flywheel or any aftermarket clutch will cause different vibrations than what is expected with a stock clutch Again mis interpreted as a misfire ( aftermarket cams are notorious for false misfires as well )
Good news is that any tuner with HP or EFILIVE knows how to correct both false misfires and false knock---It is a very common tuning issue that all tuners will correct
PS A Tech II cannot tell the difference between real misfires or knock or false ones--Only a tuner with a data logger can tell you exactly what's going on----
Desensitizing the misfire tables in your tune will eliminate all the false misfires and as well desenitizing the knock tables will eliminate false knock
Old 01-13-2017, 08:26 AM
04zjimc
04zjimc's Avatar
hi, yes I did notice when I push my stock clutch down I can watch my misfire count go up...I will be getting a dyno tune in the spring..I also have this other problem in my post above the one you had posted... feels like my brakes are being applied then feels like brakes have been released.. 90% of the time it feels like brakes are on I'm trying to figure out how to test my braking system with the tech 2? Also if if I have false misfires ho we can that effect performance?
Old 03-31-2017, 12:20 AM
tblu92
tblu92's Avatar
Mis fires as you show would show some lack in power---
If you do not hear or feel the mis fires then they are FALSE -----This can be corrected with tuning and as I mentioned in NOT uncommon with certain mods---It is an easy tuning fix--
To need help with graph on tech 2
Quick Reply: need help with graph on tech 2
