C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Why does no one make a Flex Fuel kit?
Old 01-04-2018, 12:24 PM
Podium
CF Senior Member
Liked 42 Times in 33 Posts
Originally Posted by Drewstein View Post
No reason to have flex fuel without big power, it's not worth the investment, especially NA.
That's not true at all.
Podium is online now
Old 01-04-2018, 06:10 PM
Joshboody
CF Senior Member
Liked 28 Times in 26 Posts
For older N54 turbo BMWs a piggyback computer was used (I think common for subies in the old days also)... basically intercepted various parameters including crank/cam position altering it and fudged the data back to the stock ECU to keep it happy... easily could add an E sensor. But only reason piggybacks were used is cause the ECU was so difficult to hack initially.
Joshboody is offline
Old 01-04-2018, 06:31 PM
jrp1588
CF Senior Member
Liked 44 Times in 36 Posts
I'm pretty sure that's how the FF kit on my STi worked. It intercepted the signal between the MAF sensor and ECU. When it saw there was more ethanol in the fuel, it would fudge the numbers to make the engine think more air was coming in, so it would dump more fuel. There was no direct interface with the ECU.
I don't know if there would be a way to advance timing based off ethanol content with this sort of setup though. I don't know how much use it would be NA.
jrp1588 is offline
Old 01-05-2018, 12:18 PM
Joshboody
CF Senior Member
You'd really only have to intercept crank position to raise global timing based on E and rpm... easy peasy. I'm ok with planning my fill ups and keeping gas cans at the house though
With NA just E35 does a LOT... so even if have to resort to 91 map with some E in the tank, not a big deal. And 10% swings either way in your mix, also not a big deal.
Old 01-05-2018, 01:17 PM
JoeNova
CF Senior Member
Liked 15 Times in 14 Posts
Cam sensor, you would need to read the cam sensor for timing changes. I'm working on this now with an Arduino Nano. I have a working 2-step setup with it, but it can't do timing retard.
It seems the easiest way is to send the cam sensor through the arduino and either speed up or delay the signal to the PCM. I haven't tried it yet, but it shouldn't be too hard to do.
You can use a GM flex fuel sensor. I believe the GM sensor does a 5v square wave signal so that it can do ethanol content and fuel temperature on a single signal wire. With a little programming how-to, it wouldn't be too hard to read the flex fuel signal and adjust the cam sensor based on this. Probably easier than the cam sensor would be tricking the IAT sensor to do timing adjustments and supplemental fueling.
JoeNova is offline
Old 01-05-2018, 01:22 PM
jrp1588
CF Senior Member
Yeah, I thought about the IAT sensor option. (Again, I have no tuning experience, just some basic theoretical knowledge) It seems like you might run into issues when it gets really cold in the winter though.
jrp1588 is offline
Old 01-05-2018, 01:37 PM
Joshboody
CF Senior Member
I spoke too soon... you also need to change PW for accurate fueling. This can be global since a basic % diff.
IAT for 2 maps would work, but scaling based on E seems little complicated. And for SD peeps it would alter the fueling.
I know nothing of 2 step, but couldn't you use park vs in gear cutoff tables... AFAIK ECU only references clutch and mph.
Old 01-05-2018, 01:43 PM
jrp1588
CF Senior Member
I'm way out of my depth here, but feel free to carry on. Maybe something constructive will come from it. haha
jrp1588 is offline
Old 01-05-2018, 01:46 PM
ysb02
CF Senior Member
Liked 30 Times in 29 Posts
Originally Posted by NSFW View Post
Related question - are there hobbyists involved in reverse-engineering C5 ECUs/PCMs and adding new features? If so, where do they hang out?
Not that I know of, only companies like EFI Live, HP Tuners have decoded the ecu. Most people just jump to an aftermarket ECU rather than continue to hack the stock one. The aftermarket ecus gain you so much it seems like a waste of time / money to try hacking the stock ECU after a certain point.
ysb02 is offline
Old 01-05-2018, 01:59 PM
JoeNova
CF Senior Member
Any method of using the PCM for 2 step is going to be fuel cut only (and lazy). The easiest method is the Bad VSS limit. You pass the VSS signal through a relay on the NC circuit and then use a momentary to ground the VSS signal. You end up with an artificial limiter. Works, but not very well. If you want a very responsive setup that isn't going to destroy everything, spark cut is the way to go.
Several, it depends VERY specifically on what features you're looking for.
JoeNova is offline
Old 01-06-2018, 02:36 AM
NSFW
CF Senior Member
NSFW's Avatar
Liked 39 Times in 37 Posts
I am just finishing up a project with my Subaru and it now does rev-matching for downshifts: https://github.com/LegacyNsfw/EcuHacks
I haven't got a Corvette yet, but I'm going to go look at another one tomorrow... If/when I get one I'll be wanting to do something similar. And I don't know if I could gotten as far I did with my Subaru without the help from the rest of the people in the community.
NSFW is offline
Old 01-06-2018, 07:00 PM
RonSSNova
CF Senior Member
RonSSNova's Avatar
Liked 54 Times in 52 Posts
RonSSNova is offline
Old 03-20-2018, 03:29 AM
  #33
Rkreigh
CF Senior Member
Liked 82 Times in 72 Posts
yes!
So i got around to trying this out. I got my P59 from a 04 tahoe, i took the red covers off the connector and swapped on the green. I had to move the wire from green 52 to green 75 for the alternator f terminal. I did a segment swap with a 04 z06 and brought over my injector data, idle settings, ve, maf and spark stuff over to the p59 pcm. I deleted all the o2 heater and sensor 2 DTCs and did a pcm / bcm relink. The car starts, idles and everything with the TB seems to be working fine. I didnt do all of this at once it took some time and trial and error to figure out what it wanted but thats all i had to do. I also havnt driven the car so if something different happens during driving i wouldnt know yet. I also have not hooked up a flex fuel sensor yet, it should be here in a couple days. Hopefully everything will work with that. Honestly even if it dont work swapping to the p59 is worth it to me because the newer faster pcm controls the idle of my big cam much better.
this sounds very doable. I have an 04 z06 that needs a new engine wiring harness and I have most of the parts
anyone know of some folks with expertise in doing this, willing to pay for the right hands with HP tuners, and e85 experience. sounds like a solid opportunity here!
Rkreigh is offline
The following users liked this post: Rkreigh
TastyBacon (03-21-2018)
Old 03-21-2018, 06:33 PM
  #34
TastyBacon
CF Senior Member
Liked 56 Times in 48 Posts
TastyBacon is offline
Old 03-21-2018, 06:43 PM
  #35
jrp1588
CF Senior Member
Originally Posted by Rkreigh View Post
yes!
Well, that doesn't sound overly complicated. Definitely keep us posted.
jrp1588 is offline
Old 03-21-2018, 08:49 PM
  #36
NSFW
CF Senior Member
NSFW's Avatar
Are there flex-fuel vehicles that use the 0411 PCM? Or did that PCM get the retired before flex-fuel became a thing?
NSFW is offline
Old 03-25-2018, 09:21 PM
  #37
hodge9386
CF Senior Member
hodge9386's Avatar
Liked 2 Times in 2 Posts
So that is my post from ls1tech. The PCM swap is very easy and im still tuning but so far it is coming along great. Problem is i have the flex fuel sensor plumbed, wired into the pcm and flex fuel is turned on in the tune but it is not reading alcohol percent. I have not messed with the flex fuel part any more yet but when i get the 93 tune down solid i will start messing with it again. I have been talking with james short from shortuning about this and he has figured it out by adding parameters with the user defined parameters in hp tuners but i havnt messed with it much after. He is offering this swap with flex fuel through is shop so if you are around ky then you should get in touch with him.
hodge9386 is offline
Old 03-25-2018, 09:25 PM
  #38
jrp1588
CF Senior Member
Well I'm about a stone's throw away from Kentucky actually, but not that part. That would be a good 4 hours drive at least.
jrp1588 is offline
Old 04-16-2018, 07:51 AM
  #39
Rkreigh
CF Senior Member
I have a TTiX TT Z06 and so the E85 flex fuel conversion is hot on my to do list.
If I can repin the ecm and swap in a truck ecm that already has the OS and provisions for flex fuel, and drive the gauges and get the car to run I'm in.
Can you put us in touch with Mr. Short? I'm going down to Bowling Green in mid may and could leave the car with himr to get er done.
This is a very cool approach and while not nearly as savvy as the aftermakret stuff, with a solid wide band monhitoring and a bit of talent with HP tuning the car I think I can get it to do what I want!!!
Rkreigh is offline
Old 04-17-2018, 05:19 PM
  #40
hodge9386
CF Senior Member
hodge9386's Avatar
Quick Reply: Why does no one make a Flex Fuel kit?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
