Johnny O'Connell Stage 1 Signature Series Suspension Kits - C5
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Johnny O'Connell
Stage 1
Stage 1
Looking for the most bang for the buck in your Corvette Suspension
Upgrade, then look no further than the the Johnny O'Connell Stage 1
Suspension Kit.
This kit comes with everything you need to Upgrade your Corvettes
Suspension to track level performance, while still keeping the drivablilty
of a street car. Upgrading these components will give your Corvette
a better balanced, better performing and more easily managed
suspension on the street as well as the track.
Suspension Kit.
Each Kit Includes:
- (4) Tuned Johnny O'Connell Shocks
- (F/R) Johnny O'Connell Sway Bars
- Upgraded Sway Bar End Links
- (4) Sway Bar Bushings
Get your Stage 1 Package
with
at CCA
with
at CCA
Regards
Chip
Love them! Looked at many different setups before deciding on AFE. Great ride and now I'm looking for how they perform with new rubber and a square setup. BUT, I've run into a problem that I can't find an answer to:
I had the F45 suspension and when I replaced the shocks I added the Lingenfelter simulators to fool the computer. So far so good, then I removed the center console switch and tossed it out with the shocks. They are bye bye. I know that was really dumb! Now I screwed up the ESC control module and its throwing the warning "service active suspension". I examined the suspension damping engineering drawings and determined that I need to place a resistor shunt between pins 7 and 8 of the plug that goes to the computer. I've checked everywhere on this forum for some guidance and haven't found it yet, except to find someone with a Tech II tool who is willing to deactivate the RPO F45. Unfortunately I live in Maui and there are not a lot of sources. Does any one have the answer?
According to the drawings there are 4 resistors in the switch body. If I knew the ohm value between the two corresponding pins of the switch in any one of the switch positions I could make a shunt. Can someone out there who still has an F45 make a measurement for me and send it?
It would be sooooo much appreciated!
professor jim
professor jim
professor jim
professor jim
Regards
Chip
Yep, that would be, but so far I have not ben able to find them.
If you or any reader of the forum know of anyone with a trashed vette that has the suspension switch, kindly let me know, OK?
Chris,
New housing without switch hole with replacement switch which is contained in a box which snaps in place with the **** removed did the trick, just like the simulators.
BTW: what does OTD mean?
professor jim
professor jim
