C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
C5 Dash readout display lit but "stuck" on service messages
Old 06-16-2017, 02:36 PM
tonydicosta
2nd Gear
tonydicosta's Avatar
Default C5 Dash readout display lit but "stuck" on service messages
Hi Members,
Any suggestions on this? My stock 2002 C5 was showing a few service messages in the odometer area (the common "Service ABS/Traction/Active Handling"), I am not worried about that right now, will deal with later, but I used to be able to dismiss each of the service messages by pressing the dash panel "Reset" button to get back to the odometer reading. As I use the car a bit for work I need the odometer mileage but now pressing the Reset button has no effect and the service warnings continue to appear in an unending sequence, never showing the odometer. Upon start-up, the usual "Corvette" text scrolls in but then that area goes right into showing the service messages one after the other. Again, no effect pressing reset button.
I disconnected (actually I replaced) the battery (it was failing, anyway) hoping to cause a computer reboot but nothing changed. Funny thing is, even the radio did not lose its stations(!).
What's next? Reset ECU, PCM? Any suggestions I should try?
Thank you, members,
Tony
Old 06-29-2017, 12:36 PM
OUTLAW 7777
6th Gear
OUTLAW 7777's Avatar
I'm having same issue
Old 06-29-2017, 05:13 PM
tonydicosta
2nd Gear
Not getting any suggestions on this post. Looks like we have a difficult problem, Brother.
To C5 Dash readout display lit but "stuck" on service messages
Quick Reply: C5 Dash readout display lit but "stuck" on service messages
