Corvette Camaro Tuner in Tampa
Former Vendor
St. Jude Donor '12
Check out my website -->> www.TampaTuning.com
Tampa Tuning is the home for street performance tuning for $325 on Corvettes and Camaros at the stock to bolt ons level. My street tuning process takes several hours to complete. It the best way to collect scanner data for low end drivability and WOT under actual load and airflow of the vehicle.
My HP Tuners interface has unlimited credits for LS1, LS2, LS3, LS6, LS7, LSA, LS9, L99 engines
C7, Gen6 Camaros, and trucks are $100 more.
Great modification for the buck!
Instagram : TampaTuning
OUR TOTAL STREET PERFORMANCE TUNING PACKAGE FOR GM LS1-7 VEHICLES IS $325.00 WITH TRANSMISSION PACKAGE INCLUDES:
Read and reprogram your PCMs settings and perform real time scanning diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicles Air and Fuel Ratio monitored by the NGK/ AFX wideband unit
Reduction of intake air temperature table (heat soak)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active
Adjust power enrichment delay to immediate
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift pressure firmness enhanced if needed
Skip shift deleted (CAGs 1st to 4th )
Fuel injector rescaling for aftermarket injectors if needed
Cooling fan activation temperature and percentage of cooling recalculated
Perform speedometer recalibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
Phil
Tuning@TampaTuning.com
Phil
Former Vendor
St. Jude Donor '12
Fun weekend to make your car faster. Instagram= TampaTuning
www.TampaTuning.com
www.TampaTuning.com
Phil
Phil
Former Vendor
St. Jude Donor '12
Corvette Camaro Truck Tuner in Tampa
Thank you for allowing me to calibrate your Corvette. I hope each of you enjoy the three day weekend.
Phil
www.TampaTuning.com
Phil
www.TampaTuning.com
Former Vendor
St. Jude Donor '12
Good luck Florida friends with Irma.
Reach us at : Tuning@TampaTuning.com
Check out our Website: www.TampaTuning.com
Phil- Owner of Tampa Tuning.
Former Vendor
St. Jude Donor '12
Follow me on Instagram: tampatuning
Home of the Street Performance Tune starting from $325
Check out our Website>> www.TampaTuning.com
Phil
Phil
Former Vendor
St. Jude Donor '12
813-727-8720
813-727-8720
Former Vendor
St. Jude Donor '12
Corvette Tuner in Tampa
Yes I calibrate C5's
Perform speedometer re-calibration for rear gear ratio and tire size change
Email: Tuning@TampaTuning.com
www.TampaTuning.com
www.TampaTuning.com
Former Vendor
St. Jude Donor '12
Corvette Camaro tuner in Tampa
A very Happy Thanksgiving to all our friends and those of you protecting us missing out on a family dinner.
www.TampaTuning.com
Phil
www.TampaTuning.com
Phil
Neutralize rear oxygen sensors if needed
Phil
Phil
Former Vendor
St. Jude Donor '12
Camaro Corvette Truck Tuner in Tampa
813-727-8720
Corvette Camaro Truck Tuner in Tampa Orlando
813-727-8720
Phil
Phil
