SCT X4 with FREE Custom Tuning @ RDP Store..... - Page 6 - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Reload this Page >
C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Old 05-30-2018, 07:09 PM
  #101
RDP Store
Supporting Vendor
RDP Store's Avatar
Thanks for all the orders we truely appreciate your business
RDP Store is offline
Old 05-31-2018, 06:06 PM
  #102
RDP Store
Supporting Vendor
RDP Store's Avatar
we wont be beaten on service and pricing and we not only sell performance equipment but install and tune them as well so when you need tech support we are always here for you
Old 06-01-2018, 07:16 PM
  #103
RDP Store
Supporting Vendor
RDP Store's Avatar
Try the Guys at RDP Store we Offer the Best Pricing with Free Same Day Shipping to the lower 48 states and cost price anywhere else.
Old 06-02-2018, 09:32 PM
  #104
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $419.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Old 06-04-2018, 12:49 PM
  #105
RDP Store
Supporting Vendor
RDP Store's Avatar
PM us for a Great Deal with Super Forum Member Savings and Free Shipping to the Lower 48 States. Or give us a call on 440 358 5500
Old 06-05-2018, 06:57 PM
  #106
RDP Store
Supporting Vendor
RDP Store's Avatar
When i do the tuning its done from 30 years of working on the dyno tuning stock cars to 3000hp pro drag radial cars, any time we do a tune for a customer its custom tuned to suit the vehicles modifications as well as the driving style that the customer wants, also all our tunes come with a Free Lifetime Tune Update Policy which means if you add more items to your vehicle or move to a different octane of fuel all you have to do is send me a email and let me know what your doing and i will update your tuning for you for free.
If you have any questions by all means feel free to give me a call on 440 358 5500
Thanks Steve
RDP Store
Old 06-06-2018, 08:06 PM
  #107
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 06-07-2018, 09:07 PM
  #108
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store thanks all the members here for your orders and support and we look forward to working with you all in the future and welcome all new and future customers as well. Thankyou
Old 06-08-2018, 01:12 PM
  #109
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 06-09-2018, 08:49 PM
  #110
RDP Store
Supporting Vendor
RDP Store's Avatar
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Old 06-10-2018, 09:38 PM
  #111
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 06-11-2018, 07:19 PM
  #112
RDP Store
Supporting Vendor
RDP Store's Avatar
Bump For Great Savings and Free Shipping
Old 06-12-2018, 05:30 PM
  #113
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 06-13-2018, 09:26 PM
  #114
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store is a True Hands on Performance Shop and Not just a Internet Sales Business, we fit, install and Dynotune all of the Products that we sell so that we can not only sell you the parts that you need at a Great Price but we can also give you installation and tuning advice.
PM us here for More Information or give us a call on 440 358 5500 or 440 251 8571
Old 06-14-2018, 06:27 PM
  #115
RDP Store
Supporting Vendor
RDP Store's Avatar
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Old 06-15-2018, 09:18 PM
  #116
RDP Store
Supporting Vendor
RDP Store's Avatar
Fathers Day Specials Now On, pm us for details or email us at [email protected]
Old 06-16-2018, 09:33 PM
  #117
RDP Store
Supporting Vendor
RDP Store's Avatar
Great time of the year to get tuned
Old 06-17-2018, 10:28 PM
  #118
RDP Store
Supporting Vendor
RDP Store's Avatar
Thankyou for all the Purchases and your business we greatly appreciate and we value your business and support.
Old 06-19-2018, 10:49 AM
  #119
RDP Store
Supporting Vendor
RDP Store's Avatar
Not only do we Offer Great Savings but we also Offer Discounted Installations and DynoTuning as well, Pm us for a Quote and all Orders over $99 Ship for FREE to the Lower 48 States.
Old Yesterday, 06:32 PM
  #120
RDP Store
Supporting Vendor
RDP Store's Avatar
Pm us for a Deal that will blow all the others AWAY!
Forum Jump
Sponsored Ads
Vendor Directory
  • Ask a Question
Question Title:
Description:
