SCT X4 with FREE Custom Tuning @ RDP Store..... - Page 7 - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Reload this Page >
C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Old 06-21-2018, 07:13 PM
  #121
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time of the Year to get some go fast goodies on your car with our forum Member Discounts
RDP Store is offline
Old 06-22-2018, 08:21 PM
  #122
RDP Store
Supporting Vendor
RDP Store's Avatar
Hoping we can make RDP Store your go to Store, PM us for Deals and Promo Codes
Old 06-23-2018, 10:16 PM
  #123
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 06-24-2018, 07:49 PM
  #124
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Deals we wont be Beaten and we also Offer Discounted Installations
Old 06-25-2018, 08:48 PM
  #125
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $419.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Old 06-26-2018, 09:20 PM
  #126
RDP Store
Supporting Vendor
RDP Store's Avatar
pm us for more information on our specials and promo codes
Old 06-27-2018, 08:20 PM
  #127
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store wont be beaten on pricing and service to all our forum member friends here, pm us for a price with free shipping to your door
Old 06-29-2018, 05:08 PM
  #128
RDP Store
Supporting Vendor
RDP Store's Avatar
Sale Now On at www.rdpstore.com
Old 07-01-2018, 05:23 PM
  #129
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 07-02-2018, 04:14 PM
  #130
RDP Store
Supporting Vendor
RDP Store's Avatar
When i do the tuning its done from 30 years of working on the dyno tuning stock cars to 3000hp pro drag radial cars, any time we do a tune for a customer its custom tuned to suit the vehicles modifications as well as the driving style that the customer wants, also all our tunes come with a Free Lifetime Tune Update Policy which means if you add more items to your vehicle or move to a different octane of fuel all you have to do is send me a email and let me know what your doing and i will update your tuning for you for free.
If you have any questions by all means feel free to give me a call on 440 358 5500
Thanks Steve
RDP Store
Old 07-04-2018, 09:49 PM
  #131
RDP Store
Supporting Vendor
RDP Store's Avatar
thanks for the orders this 4th of july everyone
Old 07-07-2018, 03:35 PM
  #132
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 07-08-2018, 08:57 PM
  #133
RDP Store
Supporting Vendor
RDP Store's Avatar
we wont be beaten on service and pricing and we not only sell performance equipment but install and tune them as well so when you need tech support we are always here for you
Old 07-09-2018, 06:50 PM
  #134
RDP Store
Supporting Vendor
RDP Store's Avatar
Not only do we Offer Great Savings but we also Offer Discounted Installations and DynoTuning as well, Pm us for a Quote and all Orders over $99 Ship for FREE to the Lower 48 States.
Old 07-10-2018, 07:31 PM
  #135
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Deals in the USA
Old 07-11-2018, 09:02 AM
  #136
RDP Store
Supporting Vendor
RDP Store's Avatar
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Old 07-11-2018, 03:08 PM
  #137
RDP Store
Supporting Vendor
RDP Store's Avatar
Thankyou for all the orders we greatly appreciate your business
Old 07-12-2018, 10:55 AM
  #138
RDP Store
Supporting Vendor
RDP Store's Avatar
Hoping we can make RDP Store your go to store
Old 07-12-2018, 05:29 PM
  #139
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time to Save with our RDP Promo Codes and Special Deals
Old 07-13-2018, 03:03 PM
  #140
RDP Store
Supporting Vendor
RDP Store's Avatar
We would like to Thank All our Wonderful Customers here for your Business Thankyou
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
