C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
SCT X4 with FREE Custom Tuning @ RDP Store.....
Old 08-01-2018, 06:10 PM
  #161
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store wont be beaten on pricing and service to all our forum member friends here, pm us for a price with free shipping to your door
Old 08-02-2018, 09:02 PM
  #162
RDP Store
Supporting Vendor
RDP Store's Avatar
Lets Make a Deal Sale, its the Time of the Year we do our Lets Make a Deal Sale, Its for all items across the board and runs special pricing on each individual item and Brand. Simply let us know what the brand and part number is your looking for and let us do all the foot work and get you a super deal and ship for free to your door (lower 48 states)
Pm us here or give us a call on 440 358 5500
http://www.rdpstore.com
Old 08-03-2018, 06:50 PM
  #163
RDP Store
Supporting Vendor
RDP Store's Avatar
August Deals Now On
Old 08-04-2018, 10:46 AM
  #164
billy mild
billy mild's Avatar
Can this be used to remove timing when using nitrous?
RDP Store (08-04-2018)
Old 08-04-2018, 11:47 AM
  #165
RDP Store
Supporting Vendor
RDP Store's Avatar
yes sir
Old 08-04-2018, 09:37 PM
  #166
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $419.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Old 08-05-2018, 08:24 PM
  #167
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store wont be Beaten
Old 08-06-2018, 10:15 PM
  #168
RDP Store
Supporting Vendor
RDP Store's Avatar
Thankyou for your orders everyone we greatly appreciate your business and support
Old 08-07-2018, 09:15 PM
  #169
RDP Store
Supporting Vendor
RDP Store's Avatar
No one will give you a better deal than RDP Store Gaurenteed, pm us for a price and all orders ship for free to the lower 48 states
Old 08-08-2018, 07:14 PM
  #170
RDP Store
Supporting Vendor
RDP Store's Avatar
August Wheels & Deals Now on at RDP Store, PM us for a Promo Code on any item that your Looking at and we will Hook you up and Ship for Free to the Lower 48 States and cost Price Anywhere else in the World. http://www.rdpstore.com
Old 08-09-2018, 07:26 PM
  #171
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 08-11-2018, 07:45 PM
  #172
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 08-12-2018, 08:09 PM
  #173
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Deals in the USA
Old 08-13-2018, 04:18 PM
  #174
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 08-14-2018, 09:07 PM
  #175
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 08-16-2018, 08:34 PM
  #176
RDP Store
Supporting Vendor
RDP Store's Avatar
live chat now at www.rdpstore.com
Old 08-19-2018, 04:04 PM
  #177
RDP Store
Supporting Vendor
RDP Store's Avatar
To SCT X4 with FREE Custom Tuning @ RDP Store.....
Old 08-20-2018, 06:59 PM
  #178
RDP Store
Supporting Vendor
RDP Store's Avatar
In stock for immediate shipping
Old 08-21-2018, 08:08 PM
  #179
RDP Store
Supporting Vendor
RDP Store's Avatar
Time to Deal, lets put a deal together that gets you into the parts you want.
Old 12-31-2018, 05:47 PM
  #180
RDP Store
Supporting Vendor
RDP Store's Avatar
Happy New Year Everyone!!!!!!!!!
Quick Reply: SCT X4 with FREE Custom Tuning @ RDP Store.....
