Ngauge & Hp Tuners Packages at RDP Store
Supporting Vendor
RDP Store is Proud to Offer Hp Tuner Packages to the Members here wanting to do their own tuning on their cars, we have several packages available so give us a pm here or give us a call on 440 358 5500 or 440 251 8571 for more information and pricing.
Ngauge
HP Tuners nGauge 1997-2017 GM / Ford Vehicles (Credits Not Included) HPT-62001
HP Tuners nGauge for GM / Ford vehicles is the ultimate custom tuning device, datalogger and gauge ALL IN ONE! It is a digital gauge that connects to the vehicle's OBD2 port, allowing the user to view live data and reprogram the ECU. It can be tuned using HP Tuners VCM Suite and supports all OBD2 vehicles as a gauge and data logger.
Gauge Functions
- User configurable digital gauges
- Display up to 6 gauges at a time (15 if all screens are used)
- Pick from hundreds of OBD2 signals
- Record log files to MicroSD Card
- Program warning lights
- Built in diagnostics
- Can datalog 23 PIDS at a time
Optional Tuning Features
- Works with HP Tuners VCM SUite
- Read and save stock file
- Load hundreds of tunes from your MicroSD Card
Hardware Features
- 2.4" 320 x 240 Color LCD
- Resistive touch screen
- Touch Stylus included
- Micro-SD Card
- 2 Analog Inputs
- 6 Programmable LEDs
- Chrome bezel
- Brushed aluminum overlay
- Fits 3 gauge hole sizes
- Adapter Ring included
- Dual T-Slot for pedestal mounting
- Thin design to save space
- Auto Sleep/Wake with ignition
- RS232 and CAN expansion ports
- Support for Zeitronix wideband
- Firmware update through USB or MicroSD
- 2 High Speed CAN Channels
- ISO9141 / KWP2000, J1850PWM / J1850VPW
Product Features
- Credits not included.
VCM Suite Product Information
The VCM Editor utility is a comprehensive VCM/PCM programmer and parameter editor.
VCM Editors Flash utility allows the user to read the VCM/PCM flash memory and save it to a binary file. The Flash utility allows a valid calibration to be written to the VCM/PCM and also incorporates an automatic VCM/PCM recovery capabilities for ultimate protection against any reflashing problems that may be encountered.
The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few.
View the Full Features List Order VCM Suite Now!
So you're probably thinking, what else could there be for a professional tuner? Well, read on...
The VCM Suite has certain features that a professional tuner may find more useful. It includes some of the following extra capabilities.
VCM Editors Flash utility allows not just calibration reflashing and automated recovery, but entire VCM/PCM image reflashing. This means that you are free to make any operating system or calibration level modifications and flash those to the VCM/PCM. This has many uses for the advanced enthusiast, serious tuner or engine swap shop, allowing complete control over the VCM/PCM software environment.
The VCM Editor also allows for increased vehicle support for tuners, and also access to extra VCM/PCM operating system code modifcations. Tuners also have the option to modify VIN's, a useful feature for mail order VCM's.
Security. Protect your tunes with Tunerlock. Only you have the ability to read and write to VCM/PCM's that you have Tunerlocked. Prevent unwanted access to your hard work.
The VCM Scanner utility is a fully featured OBDII scanning and diagnostic tool.
It allows viewing, charting and logging of diagnostic data in real time via the vehicle OBDII diagnostic data port. It also allows viewing of vehicle Diagnostic Trouble Codes (DTC's) and other vehicle information. Built in VCM controls also supported. Command fans, closed loop, gear select, timing, air fuel ratio and more real time! No editor package can be considered complete without comprehensive scan tool capabilities.
VCM Suite is the complete package.
These components combine to make VCM Suite the most feature rich, powerful and comprehensive VCM/PCM reprogramming and diagnostics package available on the market today. In addition, our attractive make/model/year based licensing structure makes VCM Suite a clear leader in value for money.
VCM Suite is the ultimate tuning tool designed for your serious tuner and tuner shop.
Pm Us here or Give us a Call on 440 358 5500 or 440 251 8571
Ngauge
Gauge Functions
Hardware Features
- Micro-SD Card
- 2 Analog Inputs
- Chrome bezel
Product Features
Supporting Vendor
This is the simplest and most affordable modification that you can do to your Corvette. A true custom tune will give you the best bang for horsepower per dollar value of all the mods you can do. Not only will you pick HP, but also a much more visceral drivers feel from the seat of you pants to the hands on the wheel. You Corvette will be more responsive and more eager to do what Corvettes are meant to do, GO. PM or call or Email DynoSteve today and he can give you all the info you need to make the leap into a custom tune. Once you have done it you will never look back.
