Tuners, Please Step In. Question on my C6101/Predicted Airflow Table
Small question, related to a post I have going on in the General section (car goes into limp mode at WOT) but this question would be better answered here...
Do these predicted airflow values look right for a 1998 M6 C5 with the following mods (screenshot of table attached):
- LT Headers
- Callaway Honker CAI
- PRC Stage 2.5 Heads
- Cam
- LS6 Intake
This is from the initial tune I when I got my car back the first time. Car kept hitting limp mode at WOT, but the shop insists (even now) that it isn't a tune related issue.
- LT Headers
- Cam
- LS6 Intake
Luckily I had saved a copy of the tune prior to giving the car back for diagnostics, and saved another copy when I got the car back. When I compared the two, I saw that they did go in and update the predicted airflow tables and maxed the values out but they never mentioned this to me. The table in the image I posted was from when I first received the car back from the shop and had issues with REP at WOT.
When I asked about this, the response was that tuner went in and made the changes in an effort to prevent the issue from happening in the future, but they didn't tell me about it since the tune update "was not the definitive fix to this unknown issue".
Seems like it was the fix to me, but what do I know? That's why I posted the Predicted Airflow Table from my initial tune and asked if they seemed right for a car with the mods I have. Just wanted to verify for myself that this was indeed the issue.
Supporting Vendor
Instead of maxing them out and disabling your "run away throttle" protection, why not tune them.
Set up a MAP with the same axis and log dynamic grams/cylinder (will need to do a little math to get it to the milligrams), add about 10-15% buffer and paste to the table. Extrapolate any area's you may have missed. You will have to max the table for the tuning sessions so you don't go into REP.
I'm not a big fan of disabling protection/Torque Management unless it is your last resort....
Ed M
Ed M
__________________
Vette Doctors Performance aka The Vette Doctors
52 Elm Place, Amityville, NY 11701 info@thevettedoctors.com or http://www.thevettedoctors.com/
(631) 841-0779
Featuring EFI Live/HP Tuners Performance Tuning in-house or remotely and HP Tuner/EFI Live training by ERM Performance Tuning
www.ermperformancetuning.com
(631) 841-0779
Ed M
Ed M
That might be something to look into, but easier said than done for me unfortunately as I'm not a tuner and don't have the set-up to read/change the tune on my own. A buddy of mine is learning to tune his own vehicle through EFI Live so I asked for his assistance on the issue to check my calibration before/after it went to the shop for diagnostics (because I got a bad vibe when they absolutely insisted that this couldn't be a tune issue... and they still think it's not).
I was concerned about how they eventually just quietly maxed the values out as well but figured that since it's a reputable shop, they know what they're doing and just didn't want to admit a mistake. And it seems to be running fine now. ...for now at least...
But it does make me wonder if I need to have my tune double-checked by another shop or something.
Supporting Vendor
Thanks for the response.
I could give the tune a quick look over if you could post or send me the tune (c5edstoy@aol.com) and complete the attached Build questionnaire.....
Ed M
