Remote Tuning an LS3 swapped C5 - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Old 06-29-2018, 03:11 PM
mikehimself
CF Member
I thought that the 2000 ECU's were the newer style (like 04). There isn't much configurability in the old style ECU's.
mikehimself is offline
Old 07-05-2018, 12:40 AM
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default You would be better off.....
Originally Posted by nsogiba View Post
No option for "resonant" on sensor type for a 2000 C5 file. Only "Engine" and "Cylinder".
It's definitely not burst knock because I zero'd out the table that pulls burst knock timing and still get it.
You would be better off with a later model E38 ecm, harness, and knock sensors.
I've played with too many peoples "converted" engine swaps and it never works out right.
Simply put, there is no way to properly use LS1 knock sensors and an LS1 pcm to correctly/safely
detect knock when using a later model block.
EVERYONE messes with it, but there's simply no reliable way to do it right.
I've turned down more than a few jobs like this because they waste tons of time and in my opinion
never turn out right..... Considering all the money and time you put into them.
I always use an LS1 based stroker motor and change the heads to get it working right.
This way everything works out right.
Chuck CoW
Chuck CoW is offline
Old 07-18-2018, 10:27 PM
Jason Zajac
CF Member
Definitely a horrible idea
Jason Zajac is offline
Old 08-06-2018, 05:59 PM
RonSSNova
CF Senior Member
RonSSNova's Avatar
Chuck is exactly correct.
You will **** around with this forever and never know if its correct.
Brst bet is to turn them off and keep the tune conservative.
RonSSNova is offline
The Following User Says Thank You to RonSSNova For This Useful Post:
Chuck CoW (08-10-2018)
Old 08-06-2018, 06:14 PM
nsogiba
CF Senior Member
nsogiba's Avatar
After messing with all the sensitivity tables with dozens of my own iterations I have to agree, even now I'm still getting KR here and there and have no clue why.
What is considered a "safe" timing figure under WOT for a stock headed LS3/L92 with a 228/237 cam on 93 pump gas?
nsogiba is offline
Old 08-07-2018, 11:19 PM
RonSSNova
CF Senior Member
RonSSNova's Avatar
I tune my stuff. My LS1 which is just above 11:1 runs best with around 20-22 at TQ peak. Which is about 5200 in my case. Above that you can ramp it up with rpm.
A dyno will be handy. If you get it into knock, power will drop.
People say read the plugs, ok, I doubt you would see subtle knock.
I really wanted to put a 6.2 in my C5, but stroking the LS1 to 383 just makes more sense.
Old 08-08-2018, 09:19 PM
Caveboy
CF Senior Member
Caveboy's Avatar
So I should rebuild and install a stroker kit in my LS1 instead of upgrading to LS3?
Caveboy is offline
Old 08-10-2018, 05:18 AM
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
Default You want a bigger motor, build an LS1 stroker or put LS3 heads and intake on it.....
Thank you for lending support here.... It's SIMPLY NOT WORTH IT to mess around....
You want a bigger motor, build an LS1 stroker or put LS3 heads and intake on it....or BOTH...... VERY SIMPLE.
Installing a block that can not make use of the knock sensors EXACTLY HOW GM PROGRAMMED THEM.... IS STUPID.
Chuck CoW
Old 08-10-2018, 05:22 AM
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
Default Trust me...... I've tried it.
If you're having problems with 6 DEG KR up top..... you have KNOCK SENSOR PROBLEMS.
I've tuned a million of these ECMS and I've seen it many times.
Chuck CoW
__________________
Call NOW to reserve your AutoCal today!
- CLICK HERE TO FIND OUT MORE ABOUT AutoCal! -
WE ARE AN EDELBROCK AUTHORIZED E-FORCE
SUPERCHARGER DEALER and INSTALL FACILITY.
CLICK HERE: To go to the full magazine story.
Old 08-10-2018, 01:46 PM
nsogiba
CF Senior Member
nsogiba's Avatar
Chuck CoW
I don't appreciate being called stupid, especially when I'm not the only one that has ever ran a Gen 4 motor using a Gen 3 PCM (as verified by yourself in the next post). Awfully unprofessional of you given the public nature of your post
Chuck CoW
If you've done a million of these setups, do you have a meaningful suggestion for this application?
nsogiba is offline
Old 08-10-2018, 02:33 PM
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
Default Nobody called you stupid.....
Delete your post and I'll help you any way I can.
Chuck CoW
Old 08-10-2018, 06:45 PM
Podium
CF Senior Member
Chuck CoW
How is he going to use Ls3 heads on a ls1 bore?
I would run an Ls3 before a ran a ls1 based stroker. Ls1 anything is a waste of time with how cheap the 4 inch+ stuff is IMO.
Podium is offline
Old 08-10-2018, 06:46 PM
  #33
Podium
CF Senior Member
Until a cam only 08+ c6 kicks your *** lol
Podium is offline
Old 08-10-2018, 11:30 PM
  #34
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
Default Inexpensive.....
Inexpensive..... 6.0 iron block with stroker or even 6.0 by itself.... with LS3 heads and you have a very durable motor which will behave like an LS3 without the
problems using an LS1 ecm and sensors....
Or, just a 383 LS1 block and 243 heads..... Done right, you don't have to have big dollars in it.
For those reading this, you can't put LS3 heads on a stock bore LS1 as the valves will hit the cyl sleeves and the only
other option is to re-machine to shift the head dowels but not really worth it.
Many options, but again NOT worth using an LS2 or LS3 block where the knock sensors will NEVER work right.
Chuck CoW
Old 08-13-2018, 01:45 AM
  #35
Jason Zajac
CF Member
Chuck CoW
Technically any modification to the engine aside from OEM parts pretty much invalidates exact how GM programmed them. They are just piezoelectric microphones tuned to a certain frequency and mV or detection. They can be made to work with lots of work but your best bet is to figure out max timing via spark hook test and back it off a bit.
Old 08-19-2018, 05:30 PM
  #36
RonSSNova
CF Senior Member
RonSSNova's Avatar
My 346 holds its own just fine against NA C6 cars.
Its just tired, so I thought Id upgrade. Ive got a 28k mile LS1 block at the ready for a 4 crank.
Old 08-22-2018, 03:30 AM
  #37
Caveboy
CF Senior Member
Caveboy's Avatar
So if I have a 99, it is an bad idea to swap in a ls3?
Caveboy is offline
Old 09-08-2018, 07:12 PM
  #38
Caveboy
CF Senior Member
Caveboy's Avatar
Ttt
Caveboy is offline
Old 09-12-2018, 02:16 AM
  #39
Jason Zajac
CF Member
Originally Posted by Caveboy View Post
Ttt
It is fine just find a good tuner and don't worry about it
Old 09-12-2018, 02:48 PM
  #40
Chuck CoW
Supporting Vendor
Chuck CoW's Avatar
Default Build a stroked LS block....
Build a stroked LS1 or 6.0 iron block.... otherwise Knock sensors won't work. Everyone who knows better.... knows this.
The guys with non existent knock sensors...or knock sensors in the wrong location or otherwise in the wrong block/ecm configuration
are wasting time, money, and possibly much more.
Chuck CoW
Quick Reply: Remote Tuning an LS3 swapped C5
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
