Po 2138
Po 2138
I have been chasing this code for a few weeks. I have a scan tool and can remove the code even while driving. So today I decided to take off the throttle body. The car has 16000 miles (2006 C6 base coupe) and although the throttle body was not really dirty I did notice the throttle blade was not exactly tight. You could hear it rattle slightly when moving the blade. Tightened the 2 small set screws and so far no code. Could it really have been that easy?
Mike Fesi
Mike Fesi
St. Jude Donor '13-'14-'15
Mike Fesi
Mike Fesi
Remember that a drive by wire throttle as on your car does NOT have an idle air control valve that adds airflow during start up ---rather it opens the throttle blade somewhat when the key is turned on-- so the throttle should be opened slightly and that aids in starting Now there are other issues that can cause that code but they are rare on a stockish bolt on engine ---Having the throttle bolts loose would add extra airflow which is un metered by your MAF and would pop a code--so if the code does not come back your golden--
Any update
Thanks for the reply. I haven't had the code pop up since tightening the throttle body blade attachment screws. It is still hard to believe it could have been that simple, and there was no way to diagnose this particular problem. I'll take credit for being lucky instead of good on this one! The car does run better since I did the work and I hope you are correct. Thanks again!
any update on what happened I just got the same problem with my car.
Mike F.
