C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
View Poll Results: water temperature problems.
water
100.00%
trouble
0
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
help water temperature problems.
Old Jul 4, 2022 | 08:33 AM
nori's Avatar
nori
2nd Gear
Default help water temperature problems.
Everyone, please tell me.
I ride Corvette C5Z51 in Japan.
Recently, I've been worried about water temperature problems.
The temperature rises to 244°F (118°C) while driving at 40 MPH (80 km/h) 2500 rpm to 3000 rpm at 77°F (25℃)
I replaced the radiator and the water pump a 1year ago.
Please advise me why the water temperature rises.
Thank You!
Old Jul 13, 2022 | 01:42 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Are you sure you got all the air out of the system when you replaced the radiator? That could cause high temperature. You should contact a moderator to get the thread moved to the tech section.
Old Jul 23, 2022 | 06:33 PM
whatyacallit's Avatar
whatyacallit
Sticking thermostat?
Old Jul 30, 2022 | 03:06 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
1st make sure the top water hose is warm/hot after the coolant temp rises-Could be a sign of an air bubble in the system or clogged thermostat
2. LOWER the thermostat to a 160* It will not run that cool but will average around 190-195*
3. MUST do Have a tuner alter the fan settings like such only if you change the thermostat
#1 ON at 204 OFF at 196
#2 ON at 210 OFF at 205
4. If you have an auto trans check your trans fluid temperature --as these cars have a fluid cooler built into the radiator If your trans fluid is like 230-240* it will actually heat up the radiator temps
To help water temperature problems.
