C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help SERIOUS Powerloader Problem
Old Mar 22, 2003 | 07:56 PM
sbkim's Avatar
sbkim
Default Help SERIOUS Powerloader Problem
I failed to read the instructions carefully, and interupted the connection during Powerloader programming. Now the car won't start and has series of error msgs - reduce power, low fuel etc.
Could I have seriously jacked up my PCM? I have disconnected the negative terminal in hopes that it might all clear by tomorrow.
Any inputs would be greatly appreciated.
Old Mar 23, 2003 | 09:11 AM
Dave00C5's Avatar
Dave00C5
Default Re: Help SERIOUS Powerloader Problem (sbkim)
That should do it for you. Reconnect the battery and install the powerloader per the instructions. :cheers:
Old Mar 23, 2003 | 12:36 PM
sbkim's Avatar
sbkim
Dave,
Thanks but looks like it doesn't work. I have to take the pcm out to reflash... arghhH!
Old Mar 23, 2003 | 09:53 PM
RWTD's Avatar
RWTD
Dave,
Actually, just call your dealer and have them reflash it back to stock. They will not know anything is up. Just tell them that it took a dump on you, and they will read it with the Tech 2 and reflash it.
If you're worried about them possibly suspecting something, then take it to a local shop, besides a dealer, that has a Tech 2 tool.
Not to hit you while you're down, but why on earth did you buy a Powerloader with the better, less expensive options out there :confused:
I hope this helps!
Sincerely...
Old Mar 23, 2003 | 10:33 PM
sbkim's Avatar
sbkim
Default Re: Help SERIOUS Powerloader Problem (RWTD)
Actually, the car doesn't even start. So, I can I just take the PCM to them to reflash. Powerloader was the only option 4yrs ago when I was bitten by that darn mod bug :) I am really thinking about doing Predator or LS1 Edit soon
Old Mar 25, 2003 | 02:26 PM
MikeV's Avatar
MikeV
Have the dealer reflash the pcm but don't put on the powerloader if you are thinking about any other kind of programer. The powerloader locks the pcm.
MikeV
Old Mar 25, 2003 | 03:05 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Re: Help SERIOUS Powerloader Problem (MikeV)
:iagree:, of course they all do except the LS1 edit "Family" program ;)
Old Mar 25, 2003 | 04:51 PM
sbkim's Avatar
sbkim
Default Re: Help SERIOUS Powerloader Problem (ALLTHROTTLE&NOBOTTLE)
Just an FYI. So far, Steve Cole has been very proactive and responsive about helping me through this problem. It appears that PCM may be damaged and simple reflash from dealership will NOT solve my problem. As such, I am having to ship the PCM and powerloader to TTS to fix.
Old Mar 25, 2003 | 05:05 PM
RWTD's Avatar
RWTD
:eek: :crazy: :eek: :crazy: :eek: :crazy:
Please let us know if you receive it back by X-mas!
No, really though, I'm proud of Mr. Cole for actually putting his foot forward and offering you some reasonable customer service. Hopefully he will get you your pcm and Powerloader back w/in a week (it takes less than 30 min. to do what needs to be done).
FWIW, a reflash should fix the pcm entirely. I don't quite understand why he stated that, UNLESS his programming has locked to your pcm, like it normally does, which requires a dealer to have some specialty equipment, aside from just a Tech 2, to reset it.
[Modified by RWTD, 4:08 PM 3/25/2003]
Old Mar 25, 2003 | 06:53 PM
sbkim's Avatar
sbkim
I have my fingers crossed. I even threw in return Fed Ex slip (next day delivery) for his convenience. :blueangel:
To Help SERIOUS Powerloader Problem
