I just bought it for my 99 coupe its a 6 speed. I didn't do an custom programming. When it comes to cars i am an IDIOT. Should I make custom setting?? If so what should I do?? JAMES if I would have known I would of bought it from you. I only installed the performance tunning. Can you tell me what else i can do do get more out of it?? or should I just leave it?
It's okay, we all make mistakes! LOL, j/k bud, I'm playing ;) You're cool, regardless.
You have 6-speed, so shift that **** at 6k on the dot! If you powershift (who doesn't?) then you may want to bump up your rev limiter about 100 rpms to save from tagging the rev limiter, otherwise leave it be at 6190 if you speed shift instead.
Now, if you have access to a dyno you can safely play with your fuel and spark there. However, you could adjust your spark on the street, while watching for KR via the live diagnostics on the Predator.
