C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
speed sensor problem -Traction control problem
Old Apr 20, 2004 | 11:09 PM
gixxer337's Avatar
gixxer337
Default speed sensor problem -Traction control problem
Need help!!
The computer pop up a couple code. (left and right speed sensor)
Icall the dealer to get the parts but they said they don't have a sensor that is mounted on the left or right. The sensor come from one box. Does anybody know whats going on. This sensor problem effect my traction control.My back brake wear out way before my front My front bearly worn out. Help
Old Apr 26, 2004 | 10:19 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: speed sensor problem -Traction control problem (gixxer337)
There are sensors at each wheel, sometimes called WSS or "wheel speed sensor." There is also a sensor in the differential, sometimes called the VSS or "vehicle speed sensor." So there are in fact five speed sensors altogether and all can (and do sometimes!) indicate different speeds. Different enough and traction control and/or active handling gets invoked. That's why it's important for the onboard computers to run diagnostic tests to determine if they are functioning properly. If they decide the signals are bogus, they choose the safe route and disable invocation of AHS/TCS.
My guess is you're having issues with the wheel speed sensors (two acting up at once and I'd be looking at connections and control modules, probably not the sensors themselves) and the dealer is thinking about the one in the diff.
What codes are you getting? I don't think you're ready to buy parts just yet.
