Hello,
I just installed my new Z06 wheels. I did not install the tire pressure sensors on the new wheels. When I start the car I get the check tire pressure on the display. Can I use the Predator tuner to remove this code? I can only press the reset button and it goes away until I start the car again.
The reset button will start to be your new best friend, it will be like starting your car just an old habit to remind you that you have different wheels.
I have been told that if I want to run without sensors, a Corvette mechanic can program out that warning. Supposedly that is what they do on the Z06. Might want to check that out.
