C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Oxygen Sensor Problem
Old Nov 10, 2004 | 03:31 PM
Jason Evans's Avatar
Jason Evans
8th Gear
Default Oxygen Sensor Problem
I have a "Check Engine" light due to possibly using 5 gallons of leaded gas. Will the sensors burn off and clear? How do I reset the computer?
The codes say I have a problem with the right and left Oxygen sensors. I have never used any additives and only used pump gas. TX
Old Nov 10, 2004 | 04:12 PM
Mike Mercury's Avatar
Mike Mercury
do you still have cats? If so, leaded gas really screws them up... making them very restrictive - which could pop an error code falsely accusing the O2 sensors.
Old Nov 11, 2004 | 12:41 AM
Jason Evans
8th Gear
Yes, I still have the original cats. I hope I don't have to replace them. How will I know if I need to? Thanks for the reply
To Oxygen Sensor Problem
