PF-44 Oil Filter
Old Mar 11, 2005 | 08:46 PM
VettRick's Avatar
VettRick
Default PF-44 Oil Filter
I just changed the oil for the first time on my new-to-me 2001 coupe. I was surprised to find a PF-46 oil filter installed. I thought the LS1 took a PF-44? Is the PF-46 the same or a little longer? I noticed that the tune up kit sold by the Forum lists a 44 but the picture shows a 46.
What gives?
Old Mar 11, 2005 | 08:54 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
The PF44 model was discontinued. For what reason I have no idea. The model now used is the PF46.
Old Mar 11, 2005 | 08:55 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The PF-46 replaced the PF-44 a year or two ago.
No worries.
Old Mar 11, 2005 | 08:59 PM
VettRick's Avatar
VettRick
You learn something every day here on the Forum!
Thanks much.
Old Mar 11, 2005 | 09:03 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep...thats the new filter
Old Mar 20, 2005 | 10:51 PM
Shylor's Avatar
Shylor
The PF46 filter media is better and the reason it replaced the PF44.
Funny thing is the C4's LT1 used the PF52. It's a longer filter than the PF44, PF46 or UPF44. The openings on these filter are tad bigger than the PF52 but it has less filter media area. Does this mean the PF52 was overkill?
Old Mar 21, 2005 | 11:42 AM
Thunder7's Avatar
Thunder7
I have used the PF46 and it works fine. Since that one time, I have bought a case of UPF44s so I am set for quite a while now....
Old Mar 21, 2005 | 11:53 AM
blkvett01's Avatar
blkvett01
You guys might find my post on the http://forums.corvetteforum.com/show....php?t=1043634
interesting reading
Old Mar 21, 2005 | 05:59 PM
Cirrus8's Avatar
Cirrus8
I bought a case of UPF-46's from GM parts direct. I have been told that the 46's are superior to the 44's in the filter medium dept but have not seen a definitive, objective test. Since the General went to the 46's, I did too.
Old Mar 21, 2005 | 07:04 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default pf52
That's funny,my 97 V6 truck takes the PF52!! I also used it for more capacity. I cannot believe the Lt1 used this! I use the pf46 as well.
Matt
Old Mar 21, 2005 | 08:28 PM
Shylor's Avatar
Shylor
Actually the UPF46 does not exist. Did you mean UPF44? The PF46 replaced the PF44 and is superior in filter media. The UPF44 still exists and filters a lower micron level than the PF44 or PF46.
Old Mar 21, 2005 | 10:10 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
The biggest change was the anti-drainback valve they added to the pf46
Old Mar 21, 2005 | 10:48 PM
Shylor's Avatar
Shylor
I thought the biggest change was the filtering media? I'm looking at a PF46 filter right now and don't see an anti-drainback valve in it. So I don't think they have them. It wouldn't be needed anyway, the filter is mounted vertically.
To PF-44 Oil Filter
