One more time, internal or external balanced?
Old Mar 16, 2005 | 01:48 PM
VetteDrmr's Avatar
VetteDrmr
Default One more time, internal or external balanced?
I know this has been covered before, but I can't remember which way it goes.
If you're building up an LS-1 with stock parts, do you balance the rotating mass prior to engine assembly (meaning the flywheel is zero balanced), or do you balance it after buildup, using the flywheel, or something else?
My head's hurting!
TIA, and have a good one,
Mike
Old Mar 16, 2005 | 01:58 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Balance the internals and zero balance the flywheel.
Old Mar 16, 2005 | 02:12 PM
kromberg's Avatar
kromberg
Defiantely internal. If you need to change parts later, you will not have to rebalance.
Keith
To One more time, internal or external balanced?
