coolant temperature-too cool?
Dan
One of the reasons I became concerned is because 02 sensor codes are being displayed which LPE tells me is because I have high-flow cats, which they WON'T install, and I did before I took my car there. They say the codes are being displayed because the sensors sense that my exhaust is too cool. But, I had the Dynatech headers and high flow cats on the car when I drove it 750 miles to Decatur with NO codes!!!
I thought it was too low when I first warmed it up after picking the car up at Lingenfelter. I think the smartest thing for me to do would be to replace the 160 degree thermostate for a warmer one at least till summer. It's cool in NW Wisconsin even in the summer usually! It takes sometimes 2-3 hours for the check engine light to come on, (check original post in this thread). I'm stuck just S. of Madison at the moment waiting for weather to continue home. I've warmed up the engine and driven around town here several times, and no engine light!
, leave it stock. Chevy did a good job setting it up for this. If, however, you race it, and modify it for increased performance, then that is not too cold a coolant temp. Making more HP means making more heat, keeping the coolant cooler gives you a bigger "heat sink" to get rid of that heat when you go full throttle. If you increase compression (I'm at 11.4:1), running the motor cooler will reduce hot spots which cause detonation. Running a LITTLE cooler than stock (in the 175 to 190 range) will also make a few more HP than stock, if you tune for it.
Downsides: The oil life monitor will tell you to change the oil sooner. Big deal, I change mine at 5,000 miles anyway, before the oil nanny tells me to.
Decreased engine life? Again, what's your intended usage? Race motors don't last forever, I've got 5 years on mine as modified, and I bet it'll go another 5 just as strong.
Increased carbon in the combustion chamber? I suggest that is a problem for cruisers, not racers. Even so, it's not a big deal to fix, even Chevy has a fix available.
Sorry for the long post, but when this issue comes up, everyone gets so polarized in their viewpoint, there's room (and reasons) for both.
