Swapping M6 to M12
The MN6 is a better trans for performance. Instead of spending you money buying and installing a MN12 trans, get yourself a set of 4.10 gears. You will be amazed at the performance increase.
I took the MN12 trans out of my Z06 and installed a MN6 with the 4.10 gears.
Good luck with your decision.
The downside is mileage which will drop 2-3 MPG. However the 6th gear in MN6 is .50 whereas in the MN12 it is .62 which helps a little in the mileage dept.
As you don't have a 550-700 RWHP car and it is probably a street machine, I think staying with the MN6 is the best bet and going with a 3.90 or 4.10 rear gear.
As mentioned above, In a given housing size the smaller the pinion the weaker the gear, but unless you increase your power significantly or do a lot of side stepping-you'll be ok.
Now the real benefit of a 3.90 or 4.10 rear gear is that the cars performance in 3rd, 4th, 5th, and 6th will really amaze you-the high (numerically) axles really liven up driving in the usual gears that you are in most of the time.
Most of us concentrate on peak HP and what the car will do in 1st gear, what about having fun with our buddy Mr. Torque the other 99% of the time!
May the BOOST be with you!
Roy
Roy
The only valid reason for switching would be if you wanted shorter gearing and didn't want to swap out the rear end too (like say if you blew up your tranny, and needed a replacement).
Dope
4.10 maybe good for drag racing but not a chance for road racing. The corvette has soo much torque and the power band is so large the lower 4.10 gear will not help. also 4.10s limit your top speed to about 150 mph in 5th. Plus all the shifting you have to do. each time you shift you loose power. The less shifting the better for most ppl.
I have a 400 rwhp coupe with a mn6 and bumpped red line to 6750. I do 150 in 4th at 6700. ( on the track of course no street racing for me)
Gm also makes a 3.72 road racing rear end.
This is the reason why you should always do your dyno pulls in 4th as it does not stress the gearbox.
That said, no, nothing special required.
I had a plan at one point to integrate an M12 temp sensor into the DIC by sharing the oil temp display. My plan was to have the two sensors switch back and forth, at say, 5 sec. intervals, using a small IC circuit.
Probably would work o.k., as long as the PCM / BCM didn't freak out during the transition period between the two (would be in milliseconds / shouldn't be a problem. Maybe I'll do it one day..
The MN6 transmission keeps RPMs at or above the Torque Peak during the 2nd to 3rd, 3rd to 4th, and 4th to 5th shifts. See attached chart:
Only during the 4th to 5th shift does the MN12 keeps the RPMs above the Torque Peak.
Both transmissions suck when it comes to RPM loss on the 5th to 6th shift. In my Z06 I have had a custom 0.563:1 6th gear built and installed. As you can see by the red line in the above chart my RPMs stay above the Torque Peak on the 5th to 6th shift also.
Believe me, you will love your MN6 once you install either a 4.10 or 3.90 gear set.
Thanks for the note.
If you remember the speeds you can attain with a MN12 and a 3.42:1 final drive ratio at 6,500 rpm are as follows:
2nd - 68 mph
3rd - 99 mph
4th - 143 mph
5th - 170 mph
Now, I don't know how much rear wheel horsepower you have or what tires you are running at the drag strip, but I would guess that you barely out of 3rd gear.
So, I will stand by my suggestion of keeping the MN6 trans and spending the money on a 4.10 gear set.
