Z06 springs or not?
Z06 springs or not?
I have just found a used set of Z06 springs. There is a part number stamped on each of them but that part number does not match any part number at all. The front spring is stamped with part number 22171750 and the rear spring is stamped with 22188078. I looked these part numbers up at GM Parts Direct and there are no match for these numbers. I know the part numbers for the Z06 springs bet these do not match. These spring are exact fit but I want to make sure they are the correct Z06 springs.
Those are the right STAMPED part numbers. Probably the labels are gone. The one on the labeled part numbers are: Z06 Front spring: 22178729 and Z06 Rear spring: 22188038
So the stamped number and the labeled number are different? What is the stamped number for? Very
