Electrical issues, key fob, security, non start?
For awhile now my vette has been "forgetting" my fob. IE It'll be working fine and then just stop. I resynch via the lock/unlock method and it'll work immediately again. Then a day or a week later it'll stop working again.
So last night I was driving home from work and noticed the security light was on and stayed on. Thats weird.
Come into work, no light but I go to lunch and come out to start the car. Security light is on and car wont even turn over. The battery voltage looks normal. Try it a few times, wait awhile and try it again. Now the security light is one and its turning over but it wont "catch" Just VRooom and dead. try this a few times, pop the hood and look at the fuses. nothing wrong. Try again and it starts up fine.
Any idea on what is going on?
I had a wet BCM, bad grounds and a very weak battery! I bet you have a bunch of "U" series codes (loss of comms)!
Once you read and list all of the codes, clear them and see if any receient code reappear when the issue happens.
BC
In my case, I had to have the key cylinder replaced. You can try cleaning the key and the cylinder, and using your spare set of keys to see if it helps. Like Bill said, pull the codes, they usually point to the exact issue.
I know you said your battery is new. Did you check for corrosion on the positive terminal cables or any sign of acid leaking in the past? My FOB started acting up and I was constantly re-syncing it. After a few days, I popped the hood and acid was starting to leak from the battery. Pulled everything apart, cleaned it up with acid neutralizer -- wires, pcm, etc. and replaced the battery with an Optima. Worked great after that.
I have been getting the security light on the last two day myself. And it has came on in the past too, but so far hasn't caused any problem. I am thinking of taking it to the dealer and have them look at it since I have an ext warranty.
