emergency brake weirdness!?!?
Old Dec 13, 2005 | 01:51 PM
comfortracing's Avatar
comfortracing
Default emergency brake weirdness!?!?
ok, sometimes i pull up on my emergency brake and it is dead...i pump it a few times and the tension is back on it again. a few days later whamo, the tension is completely gone again till i pump it again. ok #1 WHY? #2 does it need to be fixed?
thanks guys!
Old Dec 13, 2005 | 03:38 PM
DPG's Avatar
DPG
St. Jude Donor '06
theres a write up on this.... it mentions that you can lift the handl repeatedly a few times and it forces the click wheel on the brakes to click a few over and tighten. It also mentioned that if you cannot tighten it by lifting the handle then you have to go in and take the rotors off to adjust it manually. I will try to find the post and post it.
I think this was it
https://www.corvetteforum.com/techti...=158&TopicID=1
Old Dec 13, 2005 | 06:20 PM
Goonie's Avatar
Goonie
try going in reverse and slamming on the e brake... i had a weak e break and did this a cpl of times and it tightened up a bit... im gonna take my rotor off over christmas break and tighten it myself.
Old Dec 13, 2005 | 06:24 PM
Stevedore's Avatar
Stevedore
Active Streak: 90 Days
St. Jude Donor '03-'05-'06-'07-'08,'11 thru '17, '21
thanks guys!
I had that problem. Turns out the grease in the base of the lever mechanism had thickened, or whatever, and the little ratchet pawl wasn't engaging as it should. I sprayed a little WD-40 judiciously down there, it was fixed & never had the problem again. You can do it by pulling up the base of the boot, pulling away the carpet, etc. Try it.
Old Dec 16, 2005 | 11:26 AM
comfortracing
thanks for the info guys...
To emergency brake weirdness!?!?
