no dash lights?????????????
Old Dec 17, 2005 | 06:42 PM
myvette92's Avatar
myvette92
Default no dash lights?????????????
i have no dash lights also the light that shine in the shifter.98 corvette.any ideas?thanks
Old Dec 17, 2005 | 09:35 PM
harleyrules's Avatar
harleyrules
Blown fuse? Bad ground? start there
Old Dec 17, 2005 | 10:32 PM
myvette92's Avatar
myvette92
tonight they will come on after about a mile down the road?could it be the interior dim switch?
Old Dec 18, 2005 | 12:33 PM
myvette92's Avatar
myvette92
ttt
Old Dec 18, 2005 | 01:30 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
That's my guess. If they came on momentarily that means the fuse is fine.
Old Dec 18, 2005 | 09:14 PM
myvette92's Avatar
myvette92
The Lights Will Come On About A Mile Down The Road And Stay On Until You Kill It.the N Restart It Does The Same Thing?i Can Dim It With The Switch?i Dont Know If It The Switch.could It Be The Headlamp Switch?
myvette92's Avatar
myvette92
Ttt
Old Dec 18, 2005 | 09:56 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Document ID# 402698
1999 Chevrolet/Geo Corvette
Instrument Cluster Illumination Lamps Inoperative
IPC Backlighting Inoperative Step
Action
Value(s)
Yes
No
1
Were you sent here from the IPC Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Instrument Cluster
2
Turn the ignition switch to the OFF position.
Install a scan tool.
Turn the ignition switch to the ON position.
Locate the ambient light sensor on the RH DIC switch and cover the sensor with black tape.
Using a scan tool, select IPC data display and monitor the ambient light sensor data.
Does the scan tool display the ambient light sensor data within the specified value?
0-10 Counts
Go to Step 3
Go to Step 9
3
Turn the headlamps or park lamps ON.
Rotate the dimmer switch clockwise to the full bright position.
Using a scan tool, select IPC data display and monitor the switch dimming data.
Does the scan tool display the switch dimming data within the specified value?
200-255 Counts
Go to Step 4
Go to Step 8
4
Ambient light sensor still covered.
Dimmer switch still in the full bright position.
Does the gauge backlighting illuminate?
Go to Step 5
Go to Step 6
5
Does the RH or the LH DIC switch illuminate?
Go to Step 7
Go to Step 6
6
Replace the IPC assembly. Refer to Instrument Panel Cluster (IPC) Replacement IP Cluster Replacement.
Is the replacement complete?
Go to Step 10
7
Replace the LH or the RH DIC switch assembly that did not illuminate. Refer to Driver Information Center Switch Replacement .
Go to Step 10
8
Replace the LH DIC switch assembly. Refer to Driver Information Center Switch Replacement .
Go to Step 10
9
Replace the RH DIC switch assembly. Refer to Driver Information Center Switch Replacement .
Go to Step 10
10
Turn OFF the ignition switch.
Reconnect or install any connectors or components that were disconnected or removed.
Turn ON the ignition switch.
Is the repair complete?
Old Dec 19, 2005 | 09:07 AM
js1999's Avatar
js1999
Do you have fog and tail lights, if not it is the turn signal switch.That's what was wrong with mine. Good luck
Old Dec 19, 2005 | 10:02 AM
jedicowboy's Avatar
jedicowboy
Same thing here. I bought the part from GM parts direct and installed it myself. $150.00 for an hours work vs. $500.00 and a week without the car to let the dealer do it. It was a tough choice
Easy swap out. I am not great at stuff like that either.
Old Dec 19, 2005 | 09:49 PM
dudleyd's Avatar
dudleyd
To no dash lights?????????????
