Does the C5 take ordinary Power Steering Fluid?
I was going to do the old turkey baster method and replace all my fluid. Was just wondering if it takes ordinary power steering fluid?
Thanks so much.
Jason
Thanks so much.
Jason
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
No
Power Steering System
GM Power Steering Fluid (GM P/N 1052884 (pint) or GM P/N 1050017 (quart), or equivalent)
Originally Posted by screw991le
No
Power Steering Fluid and ATF are the same fluids, just differnt colors and GM Part #s
I use Mobil I ATF in my trans, diff and powersteering. No problems. Less fluids I have to keep around.
Not according to GM, they are totally different, and in the repair manual it calls for PSF not ATF. But if it works, then use it
Cruise-In VII Veteran
and yes I ment in the diff Mobil I gear Oil.
It is like clutch fluid. It has its own part number but it is really DOT 3 brake fluid.
Some times I wonder if the floor boards in the vette are old box covers that parts came in. Oh wait. that was the Model T.
