Ultrasonic Rear Park Assist
Are you really serious? There's not really much of a blind spot. If you are serious, I'm sure someone makes a kit. Can't imagine it being a popular mod though. Unless they're paint to match sensors, they'd look awful on that big rear.
Take it easy, and good luck with the mod if you decide to try it.
You would have to buy a kit made for another car and mod it for your car. You could place them so the sensors are not seen in the rear and front of the vehicle.
here's a few I Googled:
http://www.opticsplanet.net/atnaut20bacs.html
http://www.elexp.com/kit_3502.htm
many talk about mounting these on the rear of your car. I'd like to have it monitoring the front.
Originally Posted by Mike Mercury
...many talk about mounting these on the rear of your car. I'd like to have it monitoring the front.
- Wisdom
The ATN Autopark seems to fit the area between the tailpipes. The second one seems to be a kit, I wonder if it will need housing made so it's not exposed to the elements.
What I have considered is the one with display of how many feet/meters left (saw them on eBay). It is a bit more expensive and mounting the sensors is not as easy (it requires drilling).
I installed a system on my Avalanche since they have a LARGE blind spot due to the small rear window and the high rear-end attitude. It's a Poron unit and works pretty well. I bought it on ebay about three years ago for $67 delivered.
I'd rather have a rear-view camera system but they are much more expensive.
This is a 9 year old thread...
I bought a kit to install never got around to it, on amazon you can do a search and read feed back to tell witch is good and bad
I actually bought it for a different car but it might wind up on my c5z
