Low Coolant ?
Old Jan 27, 2006 | 12:50 PM
Oldvetter's Avatar
Oldvetter
Default Low Coolant ?
I was backing out of my driveway from my garage, turned the heater way up, stopped at my mailbox to get mail, when I got back in the "LOW COOLANT" message was on my DIC.
I checked: level was okay, squeezing both upper and lower hoses moved coolant in tank, color of antifreeze was okay (no air contamination), antifreeze percentage was okay.
I have seen this subject posted before, anyone figure out what is the cause?
Old Jan 27, 2006 | 12:54 PM
Oldvetter's Avatar
Oldvetter
I just did a search, should have done it before, here is the answer (a TSB)
http://corvetteactioncenter.com/kb/q....php?qstId=259
No replies needed
Old Jan 27, 2006 | 03:10 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The sensor is bad, IMHO. You can unplug it and it will go away or change it.
To Low Coolant ?
