gas guage wacked out
Old Jan 31, 2006 | 04:14 PM
mbella2000's Avatar
mbella2000
Default gas guage wacked out
my 200 vette has 26,000 miles on it..My gas guage is dropping from over a quarter tank to 0 without warning. I park my car with over a quarter tank, I start my car in the am and the check guages light is on telling me I am out of gas...how is this posible with 26k miles on my car?
Old Jan 31, 2006 | 04:51 PM
rws.1's Avatar
rws.1
There are a lot of posts on this problem
follow this thread for advice
http://forums.corvetteforum.com/show...gas&forum_id=1
Good Luck
Old Jan 31, 2006 | 04:55 PM
dpd's Avatar
dpd
it's a common problem with fuels that have a high sulfer count[that's what sticking on the sender cards].get yourself a bottle of techron,fill up the tank and run it.it should clear up your problem
Old Jan 31, 2006 | 07:30 PM
Bob Chapman's Avatar
Bob Chapman
dpd is right - Use a bottle of Techron every other oil change. Put the Techron in the gas tank.
Old Feb 1, 2006 | 12:02 AM
mbella2000's Avatar
mbella2000
thanks. think previous owner used regular low grade octane instead of hi..ill try this first
Old Feb 1, 2006 | 12:43 AM
PierEagle's Avatar
PierEagle
Changing gas isn't gonna do it. All gas is oxygenated. This causes the fuel sender wires/board to corrode which is mostly likely giving you your problem. As suggested above, use the Chevron Techron gas additive to help eliminate the problem.
Cheers
Old Feb 1, 2006 | 01:20 AM
striper's Avatar
striper
I recently had the same problem with my car. As soon as I noticed the gauge acting wacky, ran Techron with the next two fill-ups. No more problems.
Old Feb 7, 2006 | 09:46 AM
mbella2000's Avatar
mbella2000
hmm 2 cans of techron and its been at a guarter tank for 3 days in local driving. I bet in 2 days I will wake up and it will be at 0 again. Luckily the techron was 241
Old Feb 7, 2006 | 09:58 AM
rws.1's Avatar
rws.1
If the problem is fouled fuel sending units, it can take 2-3 tankfuls of additive to clean them up. Berryman Chemtool B-12 also works and is a lot cheaper $2.79 a can from Wallmart. Another member says a six pack of drygas added to one tankful worked for him.
Also use a good gasoline that will help the cleaning process.... Shell V-power or Chevron.
They both have a high level of detergency.
see www.toptiergas.com
If the additive doesn't work then you need to check of a corroded ground. If that isn't the issue then its time to replace the 2 fuel sending units....1 in each of the two gas tanks...
To gas guage wacked out
