C5 Wander---newbie question
My guess is tires. It has the goodyear run flats and they are 85% worn.
Is this a tire issue or is it a corvette issue?
I am torn on what tires to replace with. I like the idea of a runflat but so many of you hate them.
Is there a tire that will make the car not wander soooo bad in a runflat or should i go non run flat? Also a tire that will make highway driving a little quieter would be nice.
I know this topic has been beat to death. I just need some fresh help.
It seems like lower speed is worse. However on the exspessway at 75mph she wants to move around a bit.
Steering feels great. Nice and tight. Brakes also are great.
And make sure the alignment guy sets the caster at or very close to the factory spec too. It's usually in the 6 to 7.5 degree range. Proper caster settings help a lot to prevent the "tracking" problems you mentioned. Caster involves shims and some alignment guys don't want to fool with this part. Toe and camber settings are fairly easy for them though and some of them want to get you in and get you out in a hurry. Most alignment shops have a print out of the before and after settings along with what the factory settings call for. HTH
So what non run flat should i be looking at.
Michelin Pilots were mention however i see from discountire.com they have many Michelin Pilots. Need more specs.
Does a non run flat hurt resale value
Bill
If you have any doubt as to what a C5 should drive like, go to a dealer that has a few C5 on the lot and take a couple for a test drive!
Prior to the alignment and new tires, you should inspect your suspension for any worn or damaged parts and replace anything that proves to be out of tolerance. Wheel bearing (HUBS) are an item that can cause issues like you speak of.
I ditched the run flats on my 98 and got Pilot sports. I also purchased a plug and patch kit and a small air pump from Walmart. Just like in the Z06.
Get what you like and get the alignment issue fixed. Then you will only be worried about not being able to drive it enough!!!
Most all cars with very wide tires will track off to the left or right when going over irregular road surfaces like at an inner section where there are ruts in the road from heavy traffic. My C4 was really bad and the suspension was in good condition and it was properly aligned!!
On a normal road surface it should drive straight and stop straight! Make a post in you regional forum section (ie. NORTHEAST SECTION and see if there are any forum members who live close that will let you compare rides. You will learn TONS of info and may make a couple of new friends. Where do you live??
Bill Curlee
00247 is on the mark. I had the same problem with my 99. Changed to Nitto non-run flats and got an alignment with specs as mentioned above. No more darting and the ride is alot quieter and smoother. From what I've been told and read about on this fourm is that factory spec's on the alignment will cause the front tires to wear out quicker on the inside ( One of my problems).
Mine is as follows and I get above 20K miles (At 24K right now on the fronts) out of a set of Kumho Ecsta MX tires:
Front
Caster 7.0+
Camber 1.2-
toe +1/32 to 0
Rear
Camber 1.0-
Toe -1/32 - 1/16-
Rake and ride height are near stock. Car didn't previously handle as well when it was lowered over 1inch below stock and didn't rotate as well around high speed corners.
Regardless of the tires you end up with, I'm with Bill Curlee. You have an alignment issue.
Mike
I'm in the boston area and out roads are so worn and cupped that stoplights on a lot of the secondary highways have 2" deep depressions down every travel lane from wear. This is normal and is what every car with wide tires and stiff suspension does. Dont waste your money on an alignment if your tire wear pattern is not all messed up or if on a new low pitched road the thing tracks straight.
Michigan in Hudsonville.
I would love to talk to a couple Vette freaks in my area.
I will check the wear pattern on the tires tonight. It seems it was
pretty flat all the way across but not sure. I can say the front tires
have only 1/32 to 2/32 tread depth.
If i go 4 new firestone runflats i will have two rears for sale.
How much could i sell them for. I think they have less than 5000
miles on them.
I did notice on roads that are cupped she seemed to pull around a bit.
Maybe what i am feeling is normal??????
