I have used, NAPA Gold, Wix, Purolator, AC, Mobil1, K&N.
The challenge is you won't be able to tell a good one from a better one for thousands of miles....
It is a balance between filterability, and flow..... take your pick of any of the available name brands.... ( like others, I avoid Fram)
this is going to be hashed to death... Use just about anything you want. I would stay away from fram because they are known to have problems being that the inside is basically cardboard literally. I use K&N simply because of the ease of taking the filter off.
