Lights On The Dash Question
Old Feb 23, 2006 | 09:36 AM
NCOMNC5's Avatar
NCOMNC5
Default Lights On The Dash Question
I notice recently a couple of backlights have buned out on my dash IE. the one for the fuel and the reset buttons. Can I pry (and I don't like that word ) the cover off and just replace the bulbs or do I have to loosen or remove the dash to get to them.
Thanks for your help
Old Feb 23, 2006 | 10:20 AM
ikaros74's Avatar
ikaros74
You do need to take the instrument cluster out in order to change the bulb... Here's a link to an instruction (by SPDKILZ for LED light replacement..) on how to get it out. Hope this helps.
http://www.spdkilz.com/techtipledhvac.html
Old Feb 23, 2006 | 12:04 PM
ALLEGRO's Avatar
ALLEGRO
Old Feb 23, 2006 | 02:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats a GREAT web site!!!!!
Old Feb 23, 2006 | 04:20 PM
SpdKilz's Avatar
SpdKilz
Old Feb 23, 2006 | 05:08 PM
NCOMNC5's Avatar
NCOMNC5
Default Thank You
thanks, I was aware of the website and it contains great info. I do need to remove my HVAC, thats how I found the site when I posted a previous question about problems with the HVAC display. I wouldn't do it until the weather gets a little warmer and just thought that maybo I could pop the covers off of the buttons. One more question once removed are the bulbs a pull out and push in type or will I need to cut and/or sodder them in place.
TTT
Old Feb 23, 2006 | 05:49 PM
usd2sing's Avatar
usd2sing
nicely done SPD..big kudos..
question what type of resistor is needed for the 12v bulbs? the ones that are in there dont seem to have a resistor inline..???
Old Feb 23, 2006 | 08:10 PM
SpdKilz's Avatar
SpdKilz
Thanks for the compliments!
The normal 12v bulbs do not need any resistors. They are specifically made to be able to handle the 12v current of a car. It is only the LEDs that you need worry about resistors. If you do put in LEDs, the rule of thumb is a 470ohm resistor.
Carleton
Old Feb 23, 2006 | 10:18 PM
usd2sing's Avatar
usd2sing
Carleton
To Lights On The Dash Question
