Simple question, cam or headers?
Old Mar 1, 2006 | 09:16 PM
Billdog350's Avatar
Billdog350
Default Simple question, cam or headers?
Looking for opinions on which to do first. Both will be done in time...but since they're about the same cost, which would be better first?
I have heard longtubes are good for approx 30-40rwhp and aggressive cams for 40-50rwhp.
Old Mar 1, 2006 | 09:17 PM
BlownV6's Avatar
BlownV6
LT's before cams
Old Mar 1, 2006 | 09:20 PM
mdhmi's Avatar
mdhmi
I would start with the long tube headers. Much easier to swap on and off than pulling the motor apart for a cam swap.
Mark
Old Mar 1, 2006 | 09:22 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Mark
and you should know you had your apart a couple of times! Just kidding!
Old Mar 1, 2006 | 10:28 PM
NW_Vettes's Avatar
NW_Vettes
Go with the headers first and then work your way up
Old Mar 2, 2006 | 01:31 AM
Shane_S's Avatar
Shane_S
Headers first. You should do Headers before you get a cam anyway.
Shane
Old Mar 2, 2006 | 08:15 AM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
save your money do both at once sometimes its worth the wait
Old Mar 2, 2006 | 08:54 AM
Billdog350's Avatar
Billdog350
Seems that everyone agrees, LT's before cam. Thanks for your opinions guys....
Old Mar 2, 2006 | 02:20 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I was considering the same thing. Ended up going with headers first.
Old Mar 2, 2006 | 04:28 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
cam!
Old Mar 2, 2006 | 06:04 PM
Billdog350's Avatar
Billdog350
Ikester....any special reason you say cam or is it just because you want to start trouble?
I did the cam in my truck a few months ago and it really wasn't a horrible project....of course the truck had more room under the hood (I was able to climb in under there).
I'm about to do headers on the truck so I won't know the difference in difficulty but I would guess its going to be easier than the cam.
Old Mar 2, 2006 | 06:34 PM
black98c5's Avatar
black98c5
Shane
Old Mar 2, 2006 | 06:40 PM
captainpooby's Avatar
captainpooby
How much should someone look at paying for a cam swap, including the cam?
Must the springs be replaced or can you do a mild cam without springs?
Old Mar 2, 2006 | 07:11 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
No but its amazing how some members mod their cars based on votes. If your confused, why not get a consensus from the pro shops?
Old Mar 2, 2006 | 07:46 PM
C5COM67's Avatar
C5COM67
Did headers first for a couple of reasons
My buddy and I can do it ourselves on a sunny Saturday afternoon, if you dont like it, not hard to reverse and wont run hundreds of dollars in labor if a shop does it(cam)
Its a bolt-on mod vice internal to the engine and wont affect much else if it gets goofed up, and its not hard for a guy whose previous experience was oil changes and spark plugs. (me)
Its been about 8 months since the LT install and I am now ready to do a cam. Did lots of research and consulted a few tuners and guys in the car club for the right grind and any other things that go with it
( springs, rods, new chain, underdrive pulley, etc.)
Hope this helps some
Old Mar 2, 2006 | 07:49 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
One word; Headers, go with long tubes
Bob
Old Mar 2, 2006 | 08:00 PM
Billdog350's Avatar
Billdog350
Ikester, I don't look at them as "votes" as much as "consensus". I value peoples opinions here, even though I can make decisions on my own.
I've done headers (years ago on an old Firebird) and the cam more recently in my truck so I plan on doing both on the Vette.
C5COM had some good reasons behind his LT install...which I will consider.
No way I'm doing shorties, definitely long tubes...either a used set from the forum or a new set from one of the vendors.
Thanks again everyone!
To Simple question, cam or headers?
Old Mar 2, 2006 | 08:06 PM
Roadrace65's Avatar
Roadrace65
Theres no point to a cam without headers....Long Tube's
Old Mar 2, 2006 | 08:23 PM
SLPRC5's Avatar
SLPRC5
Shane
Can you do them together?
Rsty
Old Mar 2, 2006 | 09:07 PM
Billdog350's Avatar
Billdog350
Only if you can afford it. I estimate $1000+- for the headers and $800+- for the cam. My wallet will tell me what I can and can't do. Plus the car is a daily driver and I don't know how long I can go without it.
