Auto Transmission Fluid Temp
Old Mar 8, 2006 | 05:30 PM
MagRed04C5's Avatar
MagRed04C5
Default Auto Transmission Fluid Temp
My Vette is in storage and I start it every 3 weeks or so.
I have noticed that, when I bring the engine to normal operating temperature, the transmission fluid temperature gets to about 170. This is without moving the car and the outside temp was about 40 degrees.
My question: Is the trans temp achieved mainly from internal friction of moving components or does the proximity of the exhaust system have something to do with it?
Old Mar 8, 2006 | 06:11 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I would say moving internal mostly
Old Mar 8, 2006 | 06:14 PM
tiojames's Avatar
tiojames
Default a4
Most of the heat generated in an auto is from the convertor, so idling will bring up the tranny temp. By the way, the addition of a hi-stall convertor needs a tranny cooler for this same reason. Until they lock up there is slippage in them generating heat.
Old Mar 8, 2006 | 07:09 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If are that concerned, get a cooler, very cheap and very easy to install. I plan on getting one this summer
Old Mar 8, 2006 | 09:07 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
The A4's radiator has its main part for the engine coolant, and a smaller part for the tranny fluid. The heat transfer from the coolant in the radiator is heating up your tranny fluid.
Old Mar 9, 2006 | 12:47 AM
Dirty Howie's Avatar
Dirty Howie
I have a cooler and a Torque Converter. It takes a LONG time for the tranny temps to get high. Mine runs at 160ish fully warmed on the freeway.
Different story at the track though.......
DH
Old Mar 10, 2006 | 05:11 PM
Bobber's Avatar
Bobber
DH
Which bran tranny cooler do you have? And does it have a fan? What size is it?
Thanks Bobby
Old Mar 10, 2006 | 07:15 PM
Dave00C5's Avatar
Dave00C5
Old Feb 16, 2011 | 11:43 AM
hdheritageride's Avatar
hdheritageride
5th Gear
what is the 2003 corvette transmission fluid temperature when running on the higway @ 60+
milles a hour??
Old Feb 16, 2011 | 11:56 AM
lucky131969's Avatar
lucky131969
It might help to be a little less ambiguous.
Old Feb 16, 2011 | 12:03 PM
hdheritageride
5th Gear
what is the 2003 corvette transmission fluid temperature when running on the highway @ 60+ miles a hour??
Old Feb 16, 2011 | 01:54 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
With your car idling in the garage the coolant temps will spike to 200-210---However the tranny cooler runs thru your radiator so i suspect the radiator is HEATING up the tranny fluid-- Many converter companies recc to bypass the radiator trans cooler when installing a stall---along with adding an aftermarker cooler--- My trans temps went down 10-15* after I bypassed the trans radiator set-up---
You just have to use common sense when driving in very cold weather and let the car warm up thoroughly before driving---
Old Feb 20, 2011 | 08:26 PM
MagRed04C5's Avatar
MagRed04C5
5 year old thread.......Hijacked
To Auto Transmission Fluid Temp
