Screen Question again.
Old Apr 14, 2006 | 09:57 AM
DADEO1's Avatar
DADEO1
Default Screen Question again.
Back to this again.
Purchased a new 4x4 so have not been working on the vert.
Think she is mad ( the vette ) that is.
I still want to get the Z06 screens and open up the area behind for air flow.
I believe I've read that a one inch hole saw drilled in the plastic about four times will do the trick.
My question is what have others done.
I'm I thinking about this too much ?
Thanks for the advice.
Old Apr 14, 2006 | 12:08 PM
Robiwan's Avatar
Robiwan
thinking way too much....either drill out or cut out or saw out - not a big deal. be prepared for more dirt inside engine compartment
Old Apr 14, 2006 | 12:49 PM
BanditDude's Avatar
BanditDude
Old Apr 14, 2006 | 01:08 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
There is one wire that runs horizontal on the lower side of the plastic you will be cutting. Make sure it is out of the way before you fire up the chainsaw. The wire can be reached from the engine compartment.
Old Apr 14, 2006 | 01:58 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I took mine completely out...seemed kinda hard at the time, but looking back, it wasn't that hard.
jeff
Old Apr 14, 2006 | 02:25 PM
MJD's Avatar
MJD
I used a 1 1/4" hole saw and put 3 holes in each. Secured my screens with velcro. Total time: 40 min. It's a piece of cake, go ahead and do it. You're definitely thinking too much. This is a great and easy mod to do.
Old Apr 14, 2006 | 10:33 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
I seem to recall that you could also cut a hole towards the back that would allow the air to escape out, basically allowing it to flow and remove hot air. It has been a while since I read this and I have slept since then.
Old Apr 15, 2006 | 01:09 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
let me tell you this . i dont know if the screens are worth anything. put them on my car bought them from wcc the dust and dirt under the hood is horafying. then again they must be letting air in since they let everything else in. theres other ways to spend your $$$. try it you can always change back
To Screen Question again.
