Recharging the A/C
I was thinking of using this to add freon. Has anybody tried it?
http://www.partsamerica.com/ProductD...tnumber=MAC134
The port is on the passenger side of the car, next to the battery box. Look for a black cap.
I bought a tall can of R134a with Oil from O'Reileys. The can has a hose and guage mounted already on it. I checked the line and the guage read "low" almost "filled" I just turned the ac on full blast, shook the can really good and hooked it up and sprayed the refigerant in SLOWLY untill the guage reads filled. Now my AC is ice cold on both sides of the car.
I went to a company called Harbor Freight and picked up a vacuum pump specifically made for R134A systems. The pump was under $20.00 and it creates more vacuum than just running the engine. It also removes any moisture from the system. I hooked the pump up to my air compressor and attached it to the sealed system for 5-10 minutes. Once vacuum was reached I disconnected it and added R 134A to the beginning of the "alert" level. Works well so far.
I believe I read somewhere that toxic gas will form if you don't do your ac system correctly so that is why I went and bought the pump.
The moisture in the system can also cause some of the internals to form ICE and either loose efficiency or plug up all together.
There is a desiccant Bag in the receiver dryer that can take care of some moisture but not a lot. Evacuating the system also gets rid of the NON CONDENSIBLE gasses. (basically air) which will enable the system to operate more efficiently.
BC
that is the only way to remove the moisture, what is acually happening is that you are lowering the boiling point of the water or moisture so that it boils off and will be removed thru the pump. Also after you pull a deep vacum shut the pump off and watch the gauge if it comes back to "0" after pulling a deep vacum then you have a leak
that needs to be fixed.
BC
If you discharge the system (without losing any oil) and only open it for a few minutes to say (replace the pressure sensor in the suction line),, just sealing the system back up and recharging it more than likely wont hurt anything. If the system was opened for a long time or you had to replace a compressor, rubber hoses, evaporator ect ect... you really need to replace the receiver dryer and vacuum it out! Replacing big parts also requires adding refrigerant oil to the system.
You can cheat sometimes and get away with it but,,, sometimes you cant!!!!! It's that pay me a little now or a LOT later thing!
