ebay Header Install
Apr 2, 2007 | 10:33 PM
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
now we want video
MORE pics
and DYNO results (do you plan on getting a tune?)
Apr 2, 2007 | 10:40 PM
St. Jude Donor '11-'12-'13-'14-'15
If your asking me... Well, here's my problem... I live somewhere close to BFE and no one around here can do a tune, that's why I decided at the last minute to go ahead and add the rear O2s... and I'm throwing zero codes so that worked out... I would love to get a tune though, I know I'm leaving some power on the board...
Video... my digital camera can do video, do you think that would be OK? Maybe I'll put someone in the hatch area with the camera and leave the glass up and really let it rip!
No I better not...
Pics... Yes more Pics to follow when I get the welding completed!
Apr 3, 2007 | 12:43 AM
My headers will be here tomorrow and I will probably have them on by the weekend as soon as they go on my tuner will do the tune on it. I'm not sure if I will get a dyno pull or not for awhile. Dyno #s truely don't mean much to me though I prefer real world #s that matter to me an thats a drag strip which I will have the # improvements asap an will keep yall filled in.
Apr 3, 2007 | 07:28 AM
I can't wait to hear your results! My SOTP meter is happy!
Apr 3, 2007 | 09:25 AM
St. Jude Donor '06-'07-'09-'10
I'm going to LG MotorSports for Dyno Day on May 5th. I'll post the results.
Apr 3, 2007 | 09:52 AM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Quote:
Originally Posted by
STOCKER
That plug wire is gonna be burnt bad!
Apr 3, 2007 | 10:10 AM
Ikester
yeah I know, the other 3 are away quite a ways.
Dave
Apr 3, 2007 | 11:58 AM
take the sheild off and extend it
Apr 3, 2007 | 11:59 AM
what did you use to block of the Air tubes?
Apr 3, 2007 | 12:26 PM
LightFighter_GXP
what do u mean? The shield has a smaller diameter then the rubber part of the boot that will be hitting the pipe.
Dave
Apr 3, 2007 | 01:20 PM
LightFighter_GXP
No need to block em really, they'll just blow cool air on the Headers for a few minutes...
Oh! Hey I made a video with my digital camera of my Vette ideling a few blips to 2K then one to 4K... now I have to figure out of to post it!
Apr 3, 2007 | 01:25 PM
Video
Let's see if this works... Someone tell me if this worked!
http://s142.photobucket.com/albums/r...t=PICT0047.flv
Yes the car is filthy
Yes the engine was already warmed up
And yes the PCV line was disconnected! LOL I didn't catch that till afterwards and I was re-tightening the Header bolts!
Apr 3, 2007 | 01:39 PM
yeah it works and it sounds good
Patina Starting
Apr 3, 2007 | 01:40 PM
LightFighter_GXP
OK thanx, it sounded really funky on my PC, of course my speakers aren't the best I'm sure...
Man, my Driver's side A.I.R. check valve really got banged up! sheesh... I'll have to paint that!
Apr 3, 2007 | 01:49 PM
hey tstar, can you take a picd of your pass side front spark plug wire at the head? Yours doesn't seem as close to the primary as mine either
Dave
Apr 3, 2007 | 01:56 PM
Here ya go, call me Tim Dave....
It looks pretty much the same as yours I think... it is the tightest one of the eight...
Apr 3, 2007 | 02:04 PM
tim, mine is actually hitting. I may take my grinder to the boot and grind it flat a bit to see if it helps some. If not, ill have to go w/ a 45 deg boot or a heat sock.
Dave
Apr 3, 2007 | 02:06 PM
I wonder if you could loosen the Header bolts and slide it forward just a touch? It doesn't take much as the boots are high temp silicone...
