Help! passenger seal will NOT stop leaking
Old Apr 26, 2006 | 09:50 PM
5.0_CJ's Avatar
5.0_CJ
Default Help! passenger seal will NOT stop leaking
I've replaced it twice after I rebuilt the diff and installed a DTE brace, and after I spent sometime looking at it and thinking... I think it IS still the seal leaking, the case itself dosent look like it has any fluid on it, the brace is covered, as is everything on the passenger side of the car, completely caked..
the halfshaft was always covered in fluid, dripping. Ireplaced the seal with the new part number, as was the first one, and it still did it.. What could cause this? is it even possible to misalign the carrier in the diff?
This makes no sense to me and its VERY frustrating. The diff dosent leak when the car sits, only when its moving, teh halfshaft was always covered in fluid and it got flung all over the place.
Old Apr 26, 2006 | 10:59 PM
5.0_CJ's Avatar
5.0_CJ
DAMNIT!
still nothing... .I think its the seal still.. I pulled the just installed last week seal out and I see fluid behind it and pooling inside it.. how ****ing frustrating is this going to get. Is it possible to have the output shaft misaligned in the case itself? I took measurements and it looks straight in there in relation to the case, but that damn c clip always makes it look like its aligned at the bottom..
I just cant figure this crap out. It has to be comign out of this seal, and I cannot figure out why.
Old Apr 26, 2006 | 11:14 PM
usd2sing's Avatar
usd2sing
r u sure its the large seal (oring) or is it the smaller seal around the shaft itself.??
do u have any oil/fluid coming out the vent on top??? maybe over filled?
Old Apr 26, 2006 | 11:26 PM
5.0_CJ's Avatar
5.0_CJ
theres fluid all over the halfshaft, it has to be the seal. I Can't imagine fluid leaping off the top of the case and consistantly hitting the halfshaft to be flung all over the place.
the halfshaft is normalyl covered in fluid.
I just pulled the seal off (again) and it has fluid around the collar, and i noticed there was fluide underneath it, like it was leaking..
I dont see any signs the case itself is leaking like I originally thought.
what could cause that seal to leak over and over?
Old Apr 26, 2006 | 11:31 PM
5.0_CJ's Avatar
5.0_CJ
its a symmetrical seal.. I can't imagine spinning it would help. IF it did, that would be scary.
the output shaft in the differential is what aligns everything... the axle rides on the shaft and is surrounded by the seal.. Originally I thought maybe the shaft in the diff was misaligned.. but that wouldnt make any sense since the other side dosent leak, theres no vibration..etc..
I did replace both output shafts and had the whole diff disassembled and reassembled, but it all went off without a hitch, I don't think its even possible to misalign that.. it just wouldnt work so smoothly.
Old Apr 26, 2006 | 11:32 PM
5.0_CJ's Avatar
5.0_CJ
as for pinched/rolled etc.. both seals I've removed look fine, I dont see any abnormal wear or anything on either side, I was thinking the bottom of the seals might appear to be more worn, but they dont... at every angle the seals seem to be intact and symmetrical.
Old Apr 26, 2006 | 11:35 PM
usd2sing's Avatar
usd2sing
cracked side cover? check around the bolt holes. maybe...??
Old Apr 26, 2006 | 11:36 PM
5.0_CJ's Avatar
5.0_CJ
See I thought that.. but that wouldn't explain why all the fluid is all over the halfshaft.
Old Apr 26, 2006 | 11:41 PM
usd2sing's Avatar
usd2sing
i dont have my spare case laying around anymore...so i cant verify this:
can the side case be miss aligned? rotated out of normal position. i think the bolts holes are equal distances correct.? can it be rotated to a diff reference? clock it?
im just throwing it out here bro...
EDIT: pm me your addy, i'll run my manuals out to ya..
dan
Old Apr 26, 2006 | 11:45 PM
5.0_CJ's Avatar
5.0_CJ
hey dan, wish you could stop by, that would probably be a breather... lol
2408 Laredo Ct. Arlington, tX 76015
right by USA motorsports.
Old Apr 26, 2006 | 11:46 PM
usd2sing's Avatar
usd2sing
no prob bro.
give me 30-40mi. im at western center and 35w.
Old Apr 26, 2006 | 11:49 PM
usd2sing's Avatar
usd2sing
need me to bring anything?
Old Apr 26, 2006 | 11:50 PM
5.0_CJ's Avatar
5.0_CJ
hey! awesome!
Old Apr 27, 2006 | 12:03 AM
5.0_CJ's Avatar
5.0_CJ
no I'm good, I have a ton of tools. and a ton of crap everywhere, it will redefine dirty as you know it.
Old Apr 27, 2006 | 01:46 AM
5.0_CJ's Avatar
5.0_CJ
SOLVED! Thanks to Dan, had some second opinions, and we came to the conclusion its the half shaft... it has a grove in it, probably the last bit of collateral damage from the nuclear bomb explosion of the previous differential.
Super big thanks to Dan!
Does that look normal to you guys?!
Old Apr 27, 2006 | 09:59 AM
5.0_CJ's Avatar
5.0_CJ
Anyone have some insight, yout hink that would cause leaks?
Old Apr 27, 2006 | 10:53 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
YEP! I bet that you found the problem.
To Help! passenger seal will NOT stop leaking
Old Apr 27, 2006 | 01:03 PM
5.0_CJ's Avatar
5.0_CJ
I'm having trouble finding shats
Old Apr 27, 2006 | 01:23 PM
usd2sing's Avatar
usd2sing
no prob CJ. happy to help
here's a thought...???
maybe take it to a shop/machinist or something and see if they could weld/fill and then turn it, getting it back to norm...???
just a thought.
Old Apr 27, 2006 | 01:26 PM
usd2sing's Avatar
usd2sing
did u try Neverlift?
they do straight axle swaps, they may have one or may be able to point u to somebody...
