1.8 rockers
Old May 5, 2006 | 09:31 PM
Blow Torch's Avatar
Blow Torch
Default 1.8 rockers
My brother has a 99 that is stock except for a Blackwing and cats removed. Could he install the Z07 rockers (1.8) without changing his springs? It's an auto shifting at 6200
Old May 6, 2006 | 10:35 PM
debmwb's Avatar
debmwb
Would like an answer to that one too.
BTW, I've read where you have to use all exhaust rockers...the intakes will not work.
Old May 6, 2006 | 10:39 PM
willyfastz's Avatar
willyfastz
Can'r remember the cam specs of the '99 but I say the 1.8's will probably put him around 550 lift so yeah change the springs.
Old May 7, 2006 | 08:06 AM
vettenuts's Avatar
vettenuts
The rockers will accelerate the valves faster. Assuming you have some miles on the car since its a 99, I would swap over to the Z06 springs since they are only $60 or so. Not worth risking it, and not a bad upgrade. The other issue you will have is the pushrods, I would upgrade them as well since the stockers will be under a heavier load.
Old May 7, 2006 | 12:05 PM
curtbriggs's Avatar
curtbriggs
I think the C6 Z06 intake rockers are offset, so they won't fit/work.
To 1.8 rockers
