I reached my arm up in there and removed the debris from in front of the CONDENSOR. However, the radiator sits behind that. What is the best way to clean the exterior of the radiator from debris? Is there a method without having to disconnect hoses? Please advise, anyone.
I usually do it from the back blowing forward thru the fan openings as best I can. If you really want to do it right, though, unplug the fans, detatch the harness and drop the fan assembly for total access. It's not hard to do if you've got a couple good-sized jackstands.
Remove the radiator top shroud cover. It's only held on by 4 screws., you'll have to pull the air-bridge to slide it out. Then get a compressed air gun with a long snout and insert it in the space between the radiator and condenser. See the attached pic the for an example of what yuou'll find.
[IMG][/IMG]
That's what I was lookin for. Okay, looks like Ive got a few screws to remove.
You can always open the hood and drive backwards. (J/K).
Someone had a GP for a screen on here that looked like a good idea for keeping the bigger things out. I just pulled my rad, and it was pretty clean, but the A/C is full of little pebbles in between the fins. Where I live they use sand in the winter for the roads, but it's more like fine gravel, and I think that is where it came from. I bought the car with 42k miles on it, and I have 55k on it now, and I doubt that it has ever been cleaned. I have a new double core rad going in, but I am trying to figure out how to get those sand pebbled out of the A/C condenser. Vacuuming didn't do much. And the car is in the garage on jack stands with no front wheels, so a water hose is out of the question. And I would think air would make a big mess. So I may just pull the A/C condenser and clean it.
I went to Home Depot and bought a small roll of 1/4 galvinized screen. Jacked up front of car and cut screen to fit opening with snips. folded the edges over so nothing sharp was sticking out, loosened the screwws holding the pan the the front facsia, slipped the screen in between, retightened the screws and fastened the rear of the screen to the 1" square bar across the front end with nylon ties. Took about a half an hour and $7.
I have one of those cheap air blow guns with the tip removed. Then got 2 feet of metal brake line or trans cooler line (cant remember) and the fitting threads right in. Then I bent a 90 at the last inch. After you take off the cover on the radiator, you can insert the line between the rad and condensor and blow straight through while getting to all parts of it.
Used it for years as a tech.
